White tyre writing... Best method
ShawnPreece
I recently used the White tyre writing pens to fill in the "TOYO" and the "PROXES R888" on my tyres, I used pens off amazon and also from halfords but they ended up flaking off in parts within 10-15 miles of putting them on and now iv done a lot more they look a right mess..... Is there a better type of paint to use or a better method of achieving the same result?
Would need to be a flexible paint in order to stay on a tyre, I expect normal 040 when dry would just crack and fall off first time you take a corner or bump.. White plastidip could be best. Or the one Big-mark recommended, frost coat or somthing
if you want to spray it the easiest way would be to go to an art shop and get some masking fluid, just paint it generously round the letters then cover the rest of the wheel with newspaper and spray away then peel off the fluid!
i used a pen from halfrauds.. hasnt lasted well to be honest.
I hadn't thought of plastidip that could be a good shout actually...
Ahh ok haven't heard of frost coat il have a little search on it
Good idea cos yeah can see it being a long process to mask it all properly lol, not that i mind at all as would be worth doing to get good results but anything easier is always good lol, yeah both the halfords pen and the Amazon pen didn't last at all for me
