HELLBOY666 Posted April 12, 2016 Share Posted April 12, 2016 hi all getting miffed as to what is wrong with my n/a its idling at 2+k all the time and it floods the engine with so much fuel it stinks and if you turn car off 9 outta 10 times it dosent like starting you have to crank it for ages then itll spit and splutter for a while, ive stripped plenum cleaned that right out,took off icv and tps all clean but if you unplug them nothing changes on the idle does this mean it could be faulty? the only thing I can do is twist injectors and move some wires which run across the engine and the idle comes down a little but go back up after a few mins or you take it for a drive.. if anyone got any ideas let me know coz I really want a car I can jump in and drive without worrying about it not starting and revving high lol. cheers before hand. Quote Link to comment Share on other sites More sharing options...
David P Posted April 12, 2016 Share Posted April 12, 2016 Look for any fault codes, could be connection or function of inlet temp or engine temp sensors? Quote Link to comment Share on other sites More sharing options...
HELLBOY666 Posted April 12, 2016 Author Share Posted April 12, 2016 if I could find someone with correct diagnostic plug down here that would help lol Quote Link to comment Share on other sites More sharing options...
HELLBOY666 Posted April 12, 2016 Author Share Posted April 12, 2016 i will check those temp sensors coz its like its on choke all the time Quote Link to comment Share on other sites More sharing options...
David P Posted April 12, 2016 Share Posted April 12, 2016 if I could find someone with correct diagnostic plug down here that would help lol You only need a paper clip and a brain that works. Quote Link to comment Share on other sites More sharing options...
HELLBOY666 Posted April 12, 2016 Author Share Posted April 12, 2016 Lol Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted April 12, 2016 Share Posted April 12, 2016 Lol /QUOTE] hes serious check the guide section on here too see how to check diagnostic codes Quote Link to comment Share on other sites More sharing options...
HELLBOY666 Posted April 12, 2016 Author Share Posted April 12, 2016 lol I know he is serious but I bet I would fek it up and set fire to summit haha - - - Updated - - - ill go have a look at it and give the info to my m8 Quote Link to comment Share on other sites More sharing options...
HELLBOY666 Posted April 23, 2017 Author Share Posted April 23, 2017 Car is fixed I had a broken fuel pressure regulator , 2 wires were not connected to knock sensor and temp sensor very well and my ecu was being a twat so all fixed and replaced and boom runs sweet as a nut now. Quote Link to comment Share on other sites More sharing options...
