VSV Technical opertaion
Jellybean
Hi
I looked at Ians thread and MkIV article , is there a more technical article with reference to voltage
Actuators and VSVs:
There are four VSV/actuator assemblies that control the sequential turbo operation:
Intake Air Control Valve (IACV)
Exhaust Gas Control Valve (EGCV)
Exhaust Gas Bypass Valve (EGBV)
Wastegate
VSVs switch manifold pressure (boost) to and away from actuators. The actuators open/shut valve butterfly flaps.
IACV
When this switches, boost generated by #2 turbo is allowed to join the intake stream
When it isn't switched, there is a small flap in the IACV assembly that allows any boost generated by #2 turbo as it prespools to join the intake stream, preventing turbo stall.
EGCV
This allows exhaust gas to flow through #2 turbo, causing it to spin up. When it's shut, there is no gas flow through the impeller of #2 turbo and therefore it doesn't spin.
EGBV
This allows some exhaust gas to bypass the EGCV and join the output of the first turbo. It serves two purposes - one, it prespools the second turbo by allowing some exhaust gas flow through it. Two, it controls the amount of exhaust gas going through the first turbo in much the same way as a wastegate - therefore controlling the maximum boost pressure generated by #1 turbo.
Wastegate
This bypasses exhaust gas from the first turbo, lowering the overall amount of exhaust gas going through *both* turbos and controlling the maximum boost pressure generated by both turbos in parallel.
Thanks Chris! Just giving the mapper a refresher on VSV's , we are going to run her in sequential , he said he had a M800 doing it before
Pricing for the M130 looks good , might be able to get the GPR package at 60-70% reduced cost if under private license (we have the package only associated with the 2JZ crank trigger pattern) need Motec to get back, this is what John Reed is doing with his Supra firmware
