HELP! Automatic radiator boss
L337
I've bought a new radiator from tcbparts, went to tighten up the nipples for the gearbox cooler, but one just kept spinning, took it off and found no thread left at all on the boss!
I then undid the nut on the boss itself to remove that and have a look at what could be done, but it just gets almost off and the once threaded shaft pushes into the rad and let's the coolant gush out.
As far as I can tell, the boss has a shoulder inside the rad? Is there a way to remove it?
