Silece2k6 Posted April 8, 2016 Share Posted April 8, 2016 Hi. I just about to Change my injectors. So i Took of the big Stock Intake Part of manifold and in Zylinder 1 and 2 is Oil, 3-6 not Question two: My New injectors has 6 alloy Adapters fittings. Do i have to put them in without any o-ring? Gesendet von meinem E6653 mit Tapatalk Quote Link to comment Share on other sites More sharing options...
Wez Posted April 8, 2016 Share Posted April 8, 2016 When I was looking at installing different injectors I was going to have the adapters welded in place. I take it you already have a fuel controller to adjust the fueling once they are installed. Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted April 10, 2016 Share Posted April 10, 2016 How do the plugs look on 1 and 2? Might be worth doing a compression test on that as looks like you're getting blow by on those 2 cylinders Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted April 10, 2016 Share Posted April 10, 2016 Its normal for slight oil pooling in the lowest part of the intake, due to the way the std PCV system works. Quote Link to comment Share on other sites More sharing options...
