Link G4 Extreme ECU
simon197911
Came from a running car. There's been lots of talk about these on here: http://www.mkivsupra.net/vbb/showthread.php?331559-Anyone-tried-one-of-the-link-ECU-s/page10
Jamie's G2 sold for £500 here: http://www.mkivsupra.net/vbb/showthread.php?331476-Link-stand-alone-ecu&highlight=link
The G4 has even more features, drive by wire, knock control, fully sequential spark and injection etc.
There's a lot of support in the uk for these, and most reputable places will map them too. These are a really good alternative to the Syvecs for people not wanting to spend £3k+.
£850
Spec below:
Designed and built to be the best, the Xtreme delivers the results, with more functions than normally demanded by both tuner and driver:
Hardware
Eight saturated injection drives, eight ignition outputs, 11 analog volt inputs, 10 digital inputs, 10 auxiliary outputs *
Four temperature inputs
Two, thirty four pin, waterproof connectors
External, 2.5, 3, 4 or 7 bar, MAP sensor (sold separately)
CAN / RS232 port
Software - PCLink
Fast tuning with keyboard driven commands
Six hundred pages of help on "right-click"
Powerful logging analysis built into PCLink
Tabbed, user configurable layout
G4Plus Xtreme Key Features
The following list details why the G4Plus ECUs are so great, but if you talk to someone with a G4 or G4Plus system they love the powerful, smooth total experience :
OBDII%20APP
Super smooth triggering for rock solid ignition timing thanks to the precision automotive microprocessor
Lamda and AFR tuning options - switchable as per user preference
OBD2 data stream by firmware upgrade
Connect up a blue-tooth or wifi adapter (available from your Link dealer, or e-bay etc).
Live data to your phone or tablet for graphical display of the ECUs data
Compatible with smartphones & tablets
Android device Apps
Apple Apps
Re-nameable labels for inputs and outputs
20 General Purpose tables (up from 12 in G4)
Trigger Scope - Help diagnose triggering problems.
Metric and Imperial display modes - customise them how you want.
Up to 6 dimensions of Fuel and Ignition mapping
Advanced closed loop cam control (up to four cams)
5 different fuel delivery modes including sequential and staged injection
Support for 6 different ignition system types including direct spark.
77 pre-configured digital trigger modes (Aug 2013) and the ability to setup the triggers for engines without a pre-configured mode.
Rotary support - up to 4 rotor engines with sequentially staged injection.
Support for solenoid, stepper and e-throttle idle systems.
5 dimensions of boost control with three switchable tables.
Motorsport features:
Anti-lag
Launch control
Gear cut control (flat shifting)
Up to two CAN communication buses
QuickTune - automated fuel tuning assistant.
Individual cylinder ignition and injection control.
Odd-fire and 2 stroke engines
On board logging:
Looping - able to continuously log, overwriting the oldest data.
Select up to 25 parameters to log and specify the rate each one is logged at.
Advanced PC Logging
Closed Loop knock control - More filter and gain channels than G4.
Statistics
Open and Closed Loop boost control
Flex fuel capable
Limiting
RPM
MAP
2 x General Purpose
Speed
Air Conditioning system control
Starter Motor system control
Gear Detection - Now with support for CAN, Engine/Wheel speed, or Voltage based systems.
Electronic Throttle Control
Tacho output - with Tacho sweep
Speedo Output
Fuel Pump speed control
Closed Loop Lambda
Virtual Auxiliaries and Timers
Custom calibration tables for sensors
Features retained from the G4
Lightweight enclosure that incorporates an easy fit mounting bracket
Lightweight loom
Waterproof connectors
Up to 6D fuel and ignition mapping
Precision closed loop cam control (four cam, independent control)
Up to 8 channel sequential fuel and ignition
Large number configurable input and output channels
Digital triggering, all OEM patterns
Rotary - up to four rotors, fully sequentially staged injection and two rotary specific ignition modes.
OEM idle hardware supported
8 injection drives
5D boost control with three switchable tables
Motorsport features - antilag, launch, flat shift
Continuous barometric correction (on board)
CAN port
Individual cylinder correction
Odd-fire engines & two-strokes
USB tuning cable included
Statistics recording into on-board memory
Gear compensation for boost control
Real time selectable dual fuel, ignition and boost maps
Sync and crank sensors can be a combination of Hall effect, variable reluctance or optical
Boost control referenced to gear, engine speed or throttle position
Up to 4MB internal logging memory
Staged injection
Closed loop knock control
Firmware updates available online (linkecu.com)
Brief Specification
eight injection drives
eleven analog voltage inputs
four analog temperature inputs
ten digital inputs
ten auxiliary outputs
two, thirty four pin, waterproof connectors
external, 2.5 bar or 5 bar, MAP sensor (sold separately)
optional internal e-throttle upgrade
all G4Plus Storm features
No. Never found a need to to be honest. Done loads, most at least approching 500lbs/ft, never broke one, it's a myth IMHO. Use quality (and correct) fluid, change it regular (and the filter) and keep the fluid from over heating / burning.
Getting the NA valve body into TT boxes to run on the TT so that Dave P can work his magic and wide the box up to 11 seems to be the new want I get asked alot. For this reason I have begun work on a simple mappable NA 3 solenoid shift controller to work with Link so I can get rid of the stock ecu on Autos altogether.
