JackyBoi Posted April 6, 2016 Share Posted April 6, 2016 Hi guys I've just installed a single turbo twin wastegate setup onto my Toyota Supra. It's running a Syvecs S6GP, Pierburg solenoid, and two 38mm Turbosmart Ultragates. My question is how do I correctly plum in the vac hoses? I have this diagram from Google which seems to look right but I am no professional Can anyone confirm if plumbing them in this way will allow for accurate boost control, or does it need to be done differently? Thanks guys Quote Link to comment Share on other sites More sharing options...
Style Posted April 6, 2016 Share Posted April 6, 2016 Looks good to me, if your solenoid has 3 ports then the empty one just vents to atmosphere. There are other ways to do it, but I'd go for that one Quote Link to comment Share on other sites More sharing options...
JackyBoi Posted April 6, 2016 Author Share Posted April 6, 2016 Looks good to me, if your solenoid has 3 ports then the empty one just vents to atmosphere. There are other ways to do it, but I'd go for that one Thank you looks like I just need to swap the top lines to the bottom of the wastegate, then tee in the extra one for the top of them into the one that runs to the turbo (I think) God I love learning Quote Link to comment Share on other sites More sharing options...
Tsia Posted April 6, 2016 Share Posted April 6, 2016 I'm running a twin wastegate setup as well, if you're still stuck let me know and I can photograph the setup. Quote Link to comment Share on other sites More sharing options...
Lee P Posted April 6, 2016 Share Posted April 6, 2016 (edited) That diagram is correct but that's a Mac valve not the one you have http://www.syvecs.co.uk/forum/viewtopic.php?f=14&t=292&sid=50a62e63afdd96b46cb042190f55cf8d Edited April 6, 2016 by Lee P (see edit history) Quote Link to comment Share on other sites More sharing options...
JackyBoi Posted April 6, 2016 Author Share Posted April 6, 2016 I'm running a twin wastegate setup as well, if you're still stuck let me know and I can photograph the setup. PM'd That diagram is correct but that's a Mac valve not the one you have http://www.syvecs.co.uk/forum/viewtopic.php?f=14&t=292&sid=50a62e63afdd96b46cb042190f55cf8d Nice one Lee, so follow the diagram and leave the third nipple venting to atmos? Quote Link to comment Share on other sites More sharing options...
Lee P Posted April 6, 2016 Share Posted April 6, 2016 Yes and the link shows which port on the solenoids to use PM'd Nice one Lee, so follow the diagram and leave the third nipple venting to atmos? Quote Link to comment Share on other sites More sharing options...
