supra_ufo Posted April 5, 2016 Share Posted April 5, 2016 (edited) Right folks I haven't made a thread specific to the issue I am having. Many moons ago I had a problem with my speedo not working. After diagnosis, which involved removing the Speed converter it turned out the issue was the COG that sits on the speed sensor that was at fault. During that time I somehow managed to break my rev counter in the process I had a lot of things going on around this time so I cant remember exactly what I did to break it. Recent work carried out are LED conversion on the dial cluster Installation of another speed convertor / delimiter The gear selection are working and lighting up correctly when I select the gear I have tried another speedo cluster which does not work either. So its looking like a wiring fault somewhere I have wiggled the wires whilst revving the car but I get nothing! Can anyone tell me which wire it is that controls the revs from the ECU and from the back of the connector so I can test those wires please? I have also tried Ikys speed sensor incase it linked with that but the Rev counter does not work. I have seen people use aftermarket Rev gauges so surely there is a way to tap into a wire... thanks. Edited May 18, 2016 by supra_ufo (see edit history) Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted April 6, 2016 Author Share Posted April 6, 2016 __h Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted April 7, 2016 Author Share Posted April 7, 2016 __e Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted April 8, 2016 Author Share Posted April 8, 2016 __l Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted April 11, 2016 Author Share Posted April 11, 2016 __p Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted April 12, 2016 Author Share Posted April 12, 2016 __m Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted April 15, 2016 Author Share Posted April 15, 2016 __e Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 15, 2016 Share Posted April 15, 2016 A garage with a scope and the wiring diagram could easily probe from the pink / silver wire at the ecu connector through to the tachometer to see where the signal is lost, or if it's a tacho fault. At least that's how I would do it Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted May 18, 2016 Author Share Posted May 18, 2016 RESOLVED Basically at the back of the gauge was a missing screw which must of grounded it, ill post up full pictures tomorrow with a good description. I WAS SCREWED BY A SCREW! Quote Link to comment Share on other sites More sharing options...
Annabella Posted May 18, 2016 Share Posted May 18, 2016 RESOLVED Basically at the back of the gauge was a missing screw which must of grounded it, ill post up full pictures tomorrow with a good description. I WAS SCREWED BY A SCREW! Aussie twang and sounds like prisoner cell block H. Are you bee? Quote Link to comment Share on other sites More sharing options...
