Big Mark Posted April 5, 2016 Share Posted April 5, 2016 Fitted lots of part over the Easter holiday including a new radiator and a separate power steering cooler. The cooler has inputs on the side, one high and one low. Does it matter which way around this is plumbed in or not? I only ask as I've had to top the power steering fluid up 3 times since, so guessing there is air in the system (or a leak) so wondered if pipes had to go a certain way around to stop air being trapped in the system? Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 5, 2016 Share Posted April 5, 2016 In at the top out at the bottom i'd have thought, same as a water rad, I guess your cooler can flow in either direction ? Quote Link to comment Share on other sites More sharing options...
Big Mark Posted April 5, 2016 Author Share Posted April 5, 2016 Cooler is just a Mishimoto universal one so no specific direction of flow. Think I'll have to double check plumbing maybe. Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 5, 2016 Share Posted April 5, 2016 Can it actually be mounted so the feeds are horizontal, most I've seen sit with the feeds being vertical Quote Link to comment Share on other sites More sharing options...
Big Mark Posted April 5, 2016 Author Share Posted April 5, 2016 No, I only had space fo it to be on it's side. It's fitted on the Air con radiator. Quote Link to comment Share on other sites More sharing options...
