Guest Supralee12 Posted April 4, 2016 Share Posted April 4, 2016 Hi everyone I have a 1jz engine in my supra mkiv Well it's a 1.5jz to be honest . I have wired a 2jzgte ecu to the 1jz loom on the hope I can run my 550s on the 2jzgte fuel ignition map. Will I be needing any other piggy back or will it run ok with the 2jzgte ecu on 550cc injectors. The car has single turbo and a after market intake mani. Polished and ported . Has anyone tried it thanks Link to comment Share on other sites More sharing options...
trebor69 Posted April 4, 2016 Share Posted April 4, 2016 Littlenum on here will be able to answer that for you. Link to comment Share on other sites More sharing options...
Guest Supralee12 Posted April 23, 2016 Share Posted April 23, 2016 Littlenum on here will be able to answer that for you. How can I get hold of littlenum The car won't start I have power to the ecu and to the coil and to the resistor pack just turns no start Link to comment Share on other sites More sharing options...
Annabella Posted April 23, 2016 Share Posted April 23, 2016 Hi if you subscribe for a massive £10 then you can access the help files and post in all sections and PM people. Link to comment Share on other sites More sharing options...
Konrad Posted April 24, 2016 Share Posted April 24, 2016 Doubt it will run properly with standard ECU if injectors are bigger and it's single turbo. You will need some piggy back or even better stand alone ECU mate, otherwise you will kill this engine very fast. Link to comment Share on other sites More sharing options...
Guest Supralee12 Posted April 24, 2016 Share Posted April 24, 2016 Doubt it will run properly with standard ECU if injectors are bigger and it's single turbo. You will need some piggy back or even better stand alone ECU mate, otherwise you will kill this engine very fast. How will I it's a 2jzgte ecu that runs 550s? I would if I was using the 1jzgte ecu like I was and had a emanage ultimate on it but the emanage is crap so thought well wire the 2jzgte ecu in instead and run the 550s on that map Link to comment Share on other sites More sharing options...
Guest Supralee12 Posted April 24, 2016 Share Posted April 24, 2016 Link to comment Share on other sites More sharing options...
Guest Supralee12 Posted April 24, 2016 Share Posted April 24, 2016 Just had it started some reason I'm over fuelling and a bit hesitant on throttle response so got some playing to do to sort that out Link to comment Share on other sites More sharing options...
trebor69 Posted April 24, 2016 Share Posted April 24, 2016 Link to comment Share on other sites More sharing options...
Nodalmighty Posted April 25, 2016 Share Posted April 25, 2016 That will be because the 2jz-gte import ran 440cc high impedance injectors. Unless you have a UK spec ecu in which case you have a whole fist full of issues to sort before that will run right. Link to comment Share on other sites More sharing options...
Guest Supralee12 Posted April 25, 2016 Share Posted April 25, 2016 That will be because the 2jz-gte import ran 440cc high impedance injectors. Unless you have a UK spec ecu in which case you have a whole fist full of issues to sort before that will run right. Yeah it's a uk ecu with resistor pack to run 550cc injectors . What kind of issues buddy All the wiring was the same as the 1jzgte ecu match to match pinout to pinout Link to comment Share on other sites More sharing options...
Guest Supralee12 Posted April 25, 2016 Share Posted April 25, 2016 Yeah it's a uk ecu with resistor pack to run 550cc injectors . What kind of issues buddy All the wiring was the same as the 1jzgte ecu match to match pinout to pinout Lol found the problem Would help if there was fuel init . Link to comment Share on other sites More sharing options...
David P Posted April 25, 2016 Share Posted April 25, 2016 Here's a link to a thread about how to N/A-T with GTE ECU, it goes on a bit but you might pick up some info in there? http://www.clublexus.com/forums/sc-1st-gen-1992-2000/492459-2jzge-na-t-tt-ecu-mod.html Link to comment Share on other sites More sharing options...
Nodalmighty Posted April 26, 2016 Share Posted April 26, 2016 (edited) Yeah it's a uk ecu with resistor pack to run 550cc injectors . What kind of issues buddy All the wiring was the same as the 1jzgte ecu match to match pinout to pinout Well you solved the first one. So you have a 1jz-gte that came with a 2jz ecu style ecu connector? What did that come out of ? Do you have 3 x 4 wire lambda sensors and a MAF? Are the injectors not wired as 3 pairs grouped? Edited April 26, 2016 by Nodalmighty (see edit history) Link to comment Share on other sites More sharing options...
Guest Supralee12 Posted April 26, 2016 Share Posted April 26, 2016 (edited) I wired the 2jzgte ecu to the 1jzgte loom . Done the injector wiring made my own loom so it's not batch and wired in the maf runs spot on now it has fuel . I love wiring lol first in the uk to wire a 1jzgte into a supra one of the first to even put a 1jzgte into a supra going bk 8 years ago . And all forums told me it can't be done bk then . And one of the first in the uk to do a 1.5jz I'm using a wideband sensor and it sends a signal to the ecu in narrow band so it picks up a signal . But I've always struggled with finding a decent tuner specially in my area no one seems to no anything Hench the reason I slammed on the 2jzgte ecu that runs 550s so I can run 500bhp with no management. The car is modded to cope with more but again going down that road of tunning twice a year for different temps of the year etc 500£ a time not worth it so happy at 500 on the road is good enough and if needing a bit more a safc and bit bigger injectors would be good for 600 and that's plenty on these crap uk roads init Edited April 26, 2016 by Supralee12 (see edit history) Link to comment Share on other sites More sharing options...
Nodalmighty Posted April 26, 2016 Share Posted April 26, 2016 I wired the 2jzgte ecu to the 1jzgte loom . Done the injector wiring made my own loom so it's not batch and wired in the maf runs spot on now it has fuel . I love wiring lol first in the uk to wire a 1jzgte into a supra one of the first to even put a 1jzgte into a supra going bk 8 years ago . And all forums told me it can't be done bk then . And the first in the uk to do a 1.5jz I'm using a wideband sensor and it sends a signal to the ecu in narrow band so it picks up a signal . Now if you had said that at the start I would have said "Has it got any fuel in it" Link to comment Share on other sites More sharing options...
Guest Supralee12 Posted April 26, 2016 Share Posted April 26, 2016 Now if you had said that at the start I would have said "Has it got any fuel in it" Cheers buddy I'm just crap at literacy That's why I'm not on the forums much cuz I'm crap at spelling and typing lol Link to comment Share on other sites More sharing options...
Nodalmighty Posted April 26, 2016 Share Posted April 26, 2016 Cheers buddy I'm just crap at literacy That's why I'm not on the forums much cuz I'm crap at spelling and typing lol It's not easy being a wiring Jedi, you tend to miss the obvious as it's not copper wrapped in plastic. Link to comment Share on other sites More sharing options...
