Mike2JZ Posted April 4, 2016 Share Posted April 4, 2016 Took my fuel tank out yesterday to check if innards needed a clean. Luckily it was clean as a whistle, but found this sitting in the yellow fuel reserve. Anyone have any idea what this may be or if it's meant to be there? Link to comment Share on other sites More sharing options...
tooquicktostop Posted April 4, 2016 Share Posted April 4, 2016 Looks like a plastic jubilee clip of some kind Link to comment Share on other sites More sharing options...
Nodalmighty Posted April 4, 2016 Share Posted April 4, 2016 Plastic ratchet clip. You put them around pipes and squeeze them up. Link to comment Share on other sites More sharing options...
Burna Posted April 4, 2016 Share Posted April 4, 2016 It's the collar from a 'Fuel worm', they drink fuel. Link to comment Share on other sites More sharing options...
Mike2JZ Posted April 4, 2016 Author Share Posted April 4, 2016 Plastic ratchet clip. You put them around pipes and squeeze them up. Around the fuel pump pipes that sit in the tank? - - - Updated - - - It's the collar from a 'Fuel worm', they drink fuel. Ah was wondering why my fuel needle kept going to empty so often. Link to comment Share on other sites More sharing options...
Nodalmighty Posted April 4, 2016 Share Posted April 4, 2016 Although the more I look at it the less it looks like one unless it's broken. Possibly a fuel worm collar, most likely a radio tag from a octane wasp. Link to comment Share on other sites More sharing options...
Mike2JZ Posted April 4, 2016 Author Share Posted April 4, 2016 Although the more I look at it the less it looks like one unless it's broken. Possibly a fuel worm collar, most likely a radio tag from a octane wasp. Looking at the fuel pump, there didn't seem to be any place for the clip to sit around. So who knows how it got there, but supra must of been running with it in the tank like that for ages so shouldn't be any different if I take it out the tank. Thanks for the comments guys Link to comment Share on other sites More sharing options...
pedrosixfour Posted April 4, 2016 Share Posted April 4, 2016 Can't say what it is for definite but, next time you're passing Mordor, feck it into the fires of Mount Doom, just to be sure. Link to comment Share on other sites More sharing options...
Pete Posted April 4, 2016 Share Posted April 4, 2016 It's the collar from a 'Fuel worm', they drink fuel. Where's the worm now? Does the collar have an owner identity or name on it? Wallace? William? Walter? Link to comment Share on other sites More sharing options...
herbiemercman Posted April 6, 2016 Share Posted April 6, 2016 Could it be one of these inserts you can fit in the filler neck to avoid miss fueling. Link to comment Share on other sites More sharing options...
Guest Budz86 Posted April 6, 2016 Share Posted April 6, 2016 You got to be a rare breed of special to try and stick diesel in a Supra! Lol Link to comment Share on other sites More sharing options...
herbiemercman Posted April 7, 2016 Share Posted April 7, 2016 Yep i am a rare breed and i did it, but never again, it took ages to syphon out, and then had to short out the fuel pump to get the last dregs, filled up with petrol, but would stil not start, as a last resort i tried the old Indian trick and poured a cap of petrol into the air intake, it started on two pots,then back fired and set the top of the engine a blaze, it fortunately only lasted for a few seconds, but quite a scare. Eventually got it started cranking with foot flat on floor, it ran perfect after that and i put a full bottle of Whynns fuel enhancer in. Apparently this happens a lot on all cars and there are companies dedicated to recovering the situation, it only needs you to be not concentrating and you gone and done it. Herbie. Link to comment Share on other sites More sharing options...
