Found this in my fuel tank, anyone got an idea what is is
Mike2JZ
Plastic ratchet clip. You put them around pipes and squeeze them up.
Around the fuel pump pipes that sit in the tank?
- - - Updated - - -
It's the collar from a 'Fuel worm', they drink fuel.
Ah was wondering why my fuel needle kept going to empty so often.
Although the more I look at it the less it looks like one unless it's broken. Possibly a fuel worm collar, most likely a radio tag from a octane wasp.
Looking at the fuel pump, there didn't seem to be any place for the clip to sit around. So who knows how it got there, but supra must of been running with it in the tank like that for ages so shouldn't be any different if I take it out the tank. Thanks for the comments guys
Yep i am a rare breed and i did it, but never again, it took ages to syphon out, and then had to short out the fuel pump to get the last dregs, filled up with petrol, but would stil not start, as a last resort i tried the old Indian trick and poured a cap of petrol into the air intake, it started on two pots,then back fired and set the top of the engine a blaze, it fortunately only lasted for a few seconds, but quite a scare. Eventually got it started cranking with foot flat on floor, it ran perfect after that and i put a full bottle of Whynns fuel enhancer in. Apparently this happens a lot on all cars and there are companies dedicated to recovering the situation, it only needs you to be not concentrating and you gone and done it. Herbie.
