OEM High Gear Boost Spike
Jellybean
Car Toyota
Model Supra (JZA80)
Engine: 2JZGTE 6MTM (JDM)(Non VVTI)
BPU(basic performance upgrades)
• JSPEC Turbos (Ceramic)
• Apexi AVCR (1.2 BAR set)
• Whifbitz First decat with restrictor ring and Sard 2nd sport CAT(3 inch piping)
• Greddy intercooler 4"
• Tomei 264 Poncams
• HKS Silent Hi Power Exhaust
Question:
get a boost spike in high gears 5/6 , did u come across any mods on the wastegate to allow it breath better or what options would I have, different Restrictor ring?
What does it boost to in 5th and 6th with the AVCR turned off? If it's boosting above 1.2bar then it needs a smaller restrictor ring.
The AVCR has a gear based self learning feature which should adjust the boost settings through each gear, it's a feature I've never played with though on mine so not sure what's involved but the setup is explained in the user manual.
Good Question Nic , I would have to check!
AVCR is all setup to Self learn , I have just turned down the Start Duty for 5th gear alot!
Boost cut on my ECU is 1.3 bar, on the Dyno today he said she is trying to spike over
Edited by Jellybean (see edit history)
I get similar on my TT6, I have a HKS EVC.
I had to fine tune the overall gain, get 1bar on 1st, 1.2bar on 2nd, 3rd, 1.25bar on 4th, 5th, 6..
That was the best I could do.
I have a 2inch restrictor ring..
Same here on the restrictor ring but I think this is mechanical ; getting a new ECU , built in boost control , was just wondering if you can do anything with the Jspec wastegates
Have a read of the 'gear judge setting' section in the AVCR manual, once set up the boost controller will know (based on speed and rpm signal) what gear you are in.
might check the FB setting again , she how invasive the AVCR is when it detects a spike
I know the AVCR inside out , at this stage :) Dyno guy today thinks its mechanical
