OEM Intake Trac Removal?
Jellybean
Thanks just talking to Aristo now ;)
just realised the Manifold has a OEM temp sensor , would It be worth getting a threaded port in the Blank off plate?
Yours has a temp sensor fitted? I was under the impression the temp sensor would be used for aftermarket ECU's. I know I had to get a sensor welded and drilled into the manifold when I went down the AEM route.
  • 1 month later...
