Day881 Posted April 2, 2016 Share Posted April 2, 2016 Hi didn't know if I should post this here or in technical so posted in both hope that ok I am going to be fitting 15mm spacers front and 20mm spacers rear just wanted to know if I need extended bolts or the stock bolts on car will fit? Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted April 2, 2016 Share Posted April 2, 2016 Are your spacers hub centric, with studs fitted - or just slip ons? Quote Link to comment Share on other sites More sharing options...
Day881 Posted April 2, 2016 Author Share Posted April 2, 2016 Quote Link to comment Share on other sites More sharing options...
Day881 Posted April 2, 2016 Author Share Posted April 2, 2016 What ever that is I know nothing about spacers Quote Link to comment Share on other sites More sharing options...
Rob W Posted April 2, 2016 Share Posted April 2, 2016 You will need the ARP-100-7715 wheel studs, they are 1" longer then stock IIRC. They are what I fitted to mine and been fine for the last 5 plus years. Probably other brands out there, but the quality and strength is known on the ARP bits. Quote Link to comment Share on other sites More sharing options...
Day881 Posted April 2, 2016 Author Share Posted April 2, 2016 Ok thanks will that fit 15mm and 20mm Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted April 2, 2016 Share Posted April 2, 2016 They are slip on hubcentric spacers. You will definitely need longer studs. I got mine from demon tweeks, m12x1.5. I think mine are 65mm long - they're listed for vauxhall, but fit. Quote Link to comment Share on other sites More sharing options...
