Day881 Posted April 2, 2016 Share Posted April 2, 2016 Hi I am going to be fitting 15mm spacers front and 20mm rear spacers just wanted to know if I need extended bolts or the stock bolts on car will fit? Link to comment Share on other sites More sharing options...
SupraP-Z Posted April 4, 2016 Share Posted April 4, 2016 When i put 20mm spacers on mine, the stock studs stuck out of the face by about a mm. For that spacers that big i would get extended bolts, unless you are getting the kind of spacer that has bolts already attached Link to comment Share on other sites More sharing options...
Big Mark Posted April 4, 2016 Share Posted April 4, 2016 You have 2 options. Get spacers that bolt on to your existing bolts but have new studs in them which your wheels bolt to. Tho make sure that your wheels have a recess either side of the bolt holes as this is the area where the hub stud and bolt will sit when the wheel is on. Or get spacers that slip on and longer studs that go all the way through. Link to comment Share on other sites More sharing options...
Day881 Posted April 4, 2016 Author Share Posted April 4, 2016 You have 2 options. Get spacers that bolt on to your existing bolts but have new studs in them which your wheels bolt to. Tho make sure that your wheels have a recess either side of the bolt holes as this is the area where the hub stud and bolt will sit when the wheel is on. Or get spacers that slip on and longer studs that go all the way through. I decided to go with h&r 25mm spacers the ones that bolt on to standard studs this is what the back off my wheels look like will they be ok? Also I measured the back off the wheels and believe there 70.1 the inner diameter so will I need spigot rings? There rota d2s if that helps will I also need new wheel nuts? Link to comment Share on other sites More sharing options...
Day881 Posted April 4, 2016 Author Share Posted April 4, 2016 wheel nuts with 60deg tapered seats? Link to comment Share on other sites More sharing options...
