Boost (non) issue
Tsia
Turns out I'm just a tit. Upon using a reliable bit of software (The ECU and it's map sensor, plugged in to laptop) it gives me a proper boost reading, which is all in line. Guess I am just getting used to it :) It wasn't peaking as high as it should have been on the gauge due to the cold air causing it to hit the soft boost cut, I had the dial a touch too high.
Thanks guys.
