Tsia Posted April 1, 2016 Share Posted April 1, 2016 (edited) Issue resolved, user error Edited April 1, 2016 by Tsia (see edit history) Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted April 1, 2016 Share Posted April 1, 2016 Boost solenoid, vac lines, wastegate, actuator, intercooler pipes, wiring, manifold or turbo issue. Lots of potential culprits, but easily identifiable with a bit of process of elimination. Just be thankful you don't have a TT Quote Link to comment Share on other sites More sharing options...
Tsia Posted April 1, 2016 Author Share Posted April 1, 2016 Eh, thankful - but still a lot of potential things to check... somehow Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted April 1, 2016 Share Posted April 1, 2016 There's no fixed way of sorting things like this, just be methodical, look and listen for anything unusual. Or take it to a garage. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 1, 2016 Share Posted April 1, 2016 Also do a compression test Quote Link to comment Share on other sites More sharing options...
Tsia Posted April 1, 2016 Author Share Posted April 1, 2016 Turns out I'm just a tit. Upon using a reliable bit of software (The ECU and it's map sensor, plugged in to laptop) it gives me a proper boost reading, which is all in line. Guess I am just getting used to it It wasn't peaking as high as it should have been on the gauge due to the cold air causing it to hit the soft boost cut, I had the dial a touch too high. Thanks guys. Quote Link to comment Share on other sites More sharing options...
