Which transmission cooler
adam1983
Replacing my auto vvti radiator with a new mishimoto radiator and need to get a transmission cooler at the same time.
There isn't a specific supra transmission cooler from mishimoto but comes up with a universal cooler as a recommendation. Looking at whifbitz site and srd theirs are priced much higher than this one so wondered what people think?
The car it will be going on is running bpu power levels.
http://www.part-box.com/product_info.php?products_id=20281
Any other recommendations are welcome if this one doesn't seem up to the job.
Thanks
What type of fittings do you need? Or is just a rubber hose with a jubilee clip? Also is there a maximum to the number of rows required. I. For example is too much cooling bad?
Depends what sort of power you are running I think.
I'm bpu so just looking for something to cover that but not sure if the mishimoto ones would be up to the job. Maybe they are but the price difference is quite a lot compared to some others so makes me doubt if they are or not.
Don't mind spending the extra money if needs be but don't want to spend extra for no reason.
Yes same here! The SRD one doesn't look that special. Appears to be supplied with rubber tubing, where as Whifbitz one comes with aeroquip hoses.... But is a small fortune. Either way you still need to fabricate a bracket, hence I thinking of universal one. Best person to advise is probably Dave P.
