evinX Posted April 1, 2016 Share Posted April 1, 2016 So as im driving along and come to a stop i get a squealing sound under the car, near the gearbox/ cat area, id say its very much like a belt squeal but as i open the door i can hear its under the car, dont think the exhaust/sheilds would make such a noise. Only as i come to a stop and idle it squeals, the O/D is flashing so today im going to do the pink wire mod and see it that sorts anything...wrong info being sent, and the gearbox is doing something funny etc. Apart from that, any ideas? thanks, Kev Quote Link to comment Share on other sites More sharing options...
gdog1989 Posted April 1, 2016 Share Posted April 1, 2016 mine done that sounds like the same issue turned out the tensioner pulley is in need of changing on mine, I took the belt off and removed the pulley and cleaned it up and re greased it and been fine for few months, try that and if it works ideally replace it Quote Link to comment Share on other sites More sharing options...
Scooter Posted April 1, 2016 Share Posted April 1, 2016 Definitely try it without the aux belt for a bit. Start it with belt if it squeals stop it, remove aux belt restart, if it's gone you know it's something on the belt run. Quote Link to comment Share on other sites More sharing options...
David P Posted April 1, 2016 Share Posted April 1, 2016 Quote Link to comment Share on other sites More sharing options...
X13mgr Posted April 1, 2016 Share Posted April 1, 2016 https://myrubyslippersthebook.files.wordpress.com/2011/07/packrat-on-tire.jpg Defo the culprit Quote Link to comment Share on other sites More sharing options...
Fitz Posted April 1, 2016 Share Posted April 1, 2016 Aux Tensioner bearing perhaps. Mine was the same. Quote Link to comment Share on other sites More sharing options...
evinX Posted April 1, 2016 Author Share Posted April 1, 2016 But if i start it on the drive and leave it for no matter how long theres no noise from the pulleys, all look inline with no wobbles. But if i go for a drive, usually in the cold, night and early morning, coming to a stop at lights it squeals :/ Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted April 1, 2016 Share Posted April 1, 2016 Crank pulley Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted April 1, 2016 Share Posted April 1, 2016 Try going full lock on steering and see if you get a squeal. I had similar symptoms when my crank pulley was on it's last legs. Quote Link to comment Share on other sites More sharing options...
David P Posted April 1, 2016 Share Posted April 1, 2016 coming to a stop at lights it squeals :/ Brake wear indicators? Quote Link to comment Share on other sites More sharing options...
gdog1989 Posted April 1, 2016 Share Posted April 1, 2016 Yeah mine done it when damp and cold once warmed up it stopped Quote Link to comment Share on other sites More sharing options...
David P Posted April 1, 2016 Share Posted April 1, 2016 Yeah mine done it when damp and cold once warmed up it stopped My left knee is like that. Quote Link to comment Share on other sites More sharing options...
gdog1989 Posted April 1, 2016 Share Posted April 1, 2016 hahaha Quote Link to comment Share on other sites More sharing options...
evinX Posted April 1, 2016 Author Share Posted April 1, 2016 Brake wear indicators? Its like a belt squeal as if somthing was turning, shims make a different sound, id swear blind it was the belt but its under the car. - - - Updated - - - Try going full lock on steering and see if you get a squeal. I had similar symptoms when my crank pulley was on it's last legs. Got a brand new crank pulley, its firm in there Quote Link to comment Share on other sites More sharing options...
David P Posted April 1, 2016 Share Posted April 1, 2016 (edited) id swear blind it was the belt but its under the car Edited April 1, 2016 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Annabella Posted April 1, 2016 Share Posted April 1, 2016 http://www.newsbiscuit.com/wp-content/uploads/2013/04/353-three-blind-mice.jpg You've definitely got too much time on your hands Quote Link to comment Share on other sites More sharing options...
