can someone check if the price looks ok on this PC Spec
far
Standard Skylake dual core pentium @ 3.3GHz, with a Gigabyte b150 Board would suffice, 8 ddr3l and a 120 Kingston ssd. That would power two screens. Check connectivity of the monitors. Cost less than £350. If you were nearer I'd build it for you and install. It's what I do.
will that run two large 34in screens? - if you have a business doing this please let me know.
Screen size doesnt matter, its the res that counts, you could have 60" screens if they are they still 1080p then its no different to running a 24".
What are the res of your 34" screens?
Fuji are great business machines, I always recommend them but that does look a little over spec for the requirements you listed.
Very nice, I use the older none curved version the 34UM95.
They are an odd resolution as they sit between HD and 4K being 21:9 aspect ratio, pretty much any modern graphics adapter can drive a couple of 4K screens for normal desktop use it shouldnt be too much of struggle to find something in a lower price bracket, if the machine can drive two 4K you will be fine.
Don't forget amazon, normally their prices are as competitive as the ones mentioned above and if you have amazon prime, next day free delivery. I've used overclockers for years, but been cheating on them with amazon as prices can be lower when postage is factored in
What Wez said, Scan, they can spec and ready build for you. Gfx for example https://www.scan.co.uk/products/2gb-gainward-gtx-950-pcie-30-%28x16%29-6610mhz-gddr5-gpu-1026mhz-boost-1190mhz-cores-768-dp-12-hdmi-20-d
is more than adequate to power your monitors, just check connectivity........ says in the spec of each gfx card what monitor connections it can handle. For the prices you were origiannly going to pay you could buy a third complete set of parts to hot swap if needed and still have change. Parts don't tend to go wrong as much as they used too as long as you buy the better brands like Gigabyte boards etc.
Looking in the manual those monitors support thunder bolt pass through, as long as your chosen GFX supports it and has sufficient grunt and memory you can connect both monitors to the PC with a single cable, you then connect one monitor to the other using thunder bolt ;)
