mplavery Posted March 29, 2016 Share Posted March 29, 2016 Better hurry and ge this gem How the hell you can say in very good condition From the pics there is not one panel that is straight lol let alone all the rust Link to comment Share on other sites More sharing options...
Chris Bailey Posted March 29, 2016 Share Posted March 29, 2016 OMFG! Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted March 29, 2016 Share Posted March 29, 2016 :/ Link to comment Share on other sites More sharing options...
Sheefa Posted March 29, 2016 Share Posted March 29, 2016 Best find of the decade Link to comment Share on other sites More sharing options...
s-u-p-r-a Posted March 29, 2016 Share Posted March 29, 2016 Bloody hell what a bargain Link to comment Share on other sites More sharing options...
berg Posted March 30, 2016 Share Posted March 30, 2016 Link to comment Share on other sites More sharing options...
Dnk Posted March 30, 2016 Share Posted March 30, 2016 (edited) They got the silver part right 326 hp ? Edited March 30, 2016 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
Zeiretto Posted March 30, 2016 Share Posted March 30, 2016 Poor little facelift Supra. Link to comment Share on other sites More sharing options...
kitch79 Posted March 30, 2016 Share Posted March 30, 2016 Poor little facelift Supra. I think it's actually a facelifted, pre... Says its '97, it was also was imported in 97, but it's on an 'L' reg, 1993/94 year. Worst private reg EVER! Link to comment Share on other sites More sharing options...
ripped_fear Posted March 30, 2016 Share Posted March 30, 2016 They are dodgey as hell. They bought my mates na when he moved on to a Tt. It had lost allot of miles when it was up loaded to their site. Link to comment Share on other sites More sharing options...
Dnk Posted March 30, 2016 Share Posted March 30, 2016 (edited) Check out the mot history Its fail and advisory history is pretty poor and shows a very uncared for car Edited March 30, 2016 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
Zeiretto Posted March 30, 2016 Share Posted March 30, 2016 I think it's actually a facelifted, pre... Says its '97, it was also was imported in 97, but it's on an 'L' reg, 1993/94 year. Worst private reg EVER! You mean someone went through all the trouble completely facelifting it, and then it turned out like this? Even worse. Link to comment Share on other sites More sharing options...
Dnk Posted March 30, 2016 Share Posted March 30, 2016 Registration number: L154GNY Vehicle make: TOYOTA Vehicle model: SUPRA Date first used: 31 December 1993 Fuel type: Petrol Colour: Silver MOT history of this vehicle Test date: 12 August 2013 Expiry date: 11 August 2014 Test Result: Pass Odometer reading: 259,080 miles MOT test number: 1975 2482 3218 Advisory notice item(s): Parking brake lever has little reserve travel (3.1.6b) Front Headlamp has a product on the light source but not seriously reducing light output (1.7.5a) Test date: 26 July 2012 Expiry date: 11 August 2013 Test Result: Pass Odometer reading: 241,079 miles MOT test number: 4887 5800 2279 Advisory notice item(s): Offside Rear Tyre worn close to the legal limit (4.1.E.1) Nearside Rear Anti-roll bar linkage ball joint dust cover damaged, but preventing the ingress of dirt (2.4.G.2) Parking brake lever has little reserve travel (3.1.6b) Test date: 5 July 2012 Test Result: Fail Odometer reading: 241,079 miles MOT test number: 3791 1708 2172 Reason(s) for failure: Headlamp aim beam image obviously incorrect (1.8.A.1b) Nearside Rear Anti-roll bar linkage ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.4.G.2) Offside Rear Tyre(s) incorrect because different size tyres are fitted on the same axle. (4.1.A.1a) Rear Upper Suspension arm has excessive play in a ball joint (2.4.G.2) Offside Front brake disc in such a condition that it is seriously weakened (3.5.1i) Front Headlamp aim beam image obviously incorrect (1.8.A.1b) Front Brake pad(s) less than 1.5 mm thick (3.5.1g) Service brake: efficiency below requirements (3.7.B.7) Parking brake: efficiency below requirements (3.7.B.7) Brakes imbalanced across an axle (3.7.B.5b) Advisory notice item(s): Offside Rear Tyre worn close to the legal limit (4.1.E.1) Nearside Rear Tyre worn close to the legal limit (4.1.E.1) Offside Rear Anti-roll bar rubber bush deteriorated but not resulting in excessive movement (2.4.G.2) Rear registration plate deteriorated but not likely to be misread (6.3.1d) rear diffirential has Rough noise Test date: 10 August 2011 Expiry date: 11 August 2012 Test Result: Pass Odometer reading: 225,951 kms MOT test number: 4865 4222 1257 Test date: 8 August 2011 Test Result: Fail Odometer reading: 225,951 kms MOT test number: 3986 9082 1228 Reason(s) for failure: Nearside Side repeater not working (1.4.A.2c) Nearside Headlamp not working on dipped beam (1.7.5a) Offside Rear fog lamp not working (1.3.2b) Rear registration plate insecure (6.3.1b) Rear Anti-roll bar fractured (2.4.G.1) Nearside Rear Tyre has ply or cords exposed (4.1.D.1b) Offside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1) Nearside Rear Mechanical brake component has restricted free movement (3.5.1k) Parking brake: efficiency below requirements (3.7.B.7) Advisory notice item(s): Rear registration plate deteriorated but not likely to be misread (6.3.1d) Nearside Front Tyre worn close to the legal limit (4.1.E.1) Offside Front Tyre worn close to the legal limit (4.1.E.1) Nearside Rear Upper Suspension arm has slight play in a ball joint (2.4.G.2) Test date: 12 August 2010 Expiry date: 11 August 2011 Test Result: Pass Odometer reading: 213,971 miles MOT test number: 5218 9492 0299 Test date: 5 August 2009 Expiry date: 4 August 2010 Test Result: Pass Odometer reading: 193,149 kms MOT test number: 7333 7771 9276 Test date: 24 July 2009 Test Result: Fail Odometer reading: 193,149 kms MOT test number: 3842 6500 9296 Reason(s) for failure: Nearside Side repeater not working (1.4.A.2c) Nearside Front position lamp(s) not working (1.1.A.3b) Offside Front position lamp(s) not working (1.1.A.3b) Nearside Front Headlamp not in good working order adversely affecting beam image (1.2.4a) Offside Front Headlamp not in good working order adversely affecting beam image (1.2.4a) Nearside Registration plate lamp not illuminating the registration plate (1.1.C.1e) Offside Registration plate lamp not illuminating the registration plate (1.1.C.1e) Nearside Front Shock absorber has a serious fluid leak (2.7.3) Offside Front Shock absorber has a serious fluid leak (2.7.3) Nearside Rear Shock absorber has a serious fluid leak (2.7.3) Nearside Front Tyre tread depth below requirements of 1.6mm (4.1.E.1) Offside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1) Nearside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1) Nearside Front brake disc in such a condition that it is seriously weakened (3.5.1i) Offside Front brake disc in such a condition that it is seriously weakened (3.5.1i) Nearside Rear brake disc excessively pitted (3.5.1h) Offside Rear brake disc excessively pitted (3.5.1h) Parking brake: efficiency below requirements (3.7.B.7) Test date: 4 July 2008 Expiry date: 3 July 2009 Test Result: Pass Odometer reading: 173,214 kms MOT test number: 6034 3658 8144 Advisory notice item(s): Offside Front Shock absorber has a light misting of oil (2.7.3) Test date: 26 June 2008 Test Result: Fail Odometer reading: 172,927 kms MOT test number: 1247 6877 8152 Reason(s) for failure: Headlamp aim too high (1.8) Offside Rear fog lamp excessively damaged so that it is not visible from a reasonable distance (1.3.2d) Windscreen wiper does not clear the windscreen effectively (8.2.2) Nearside Front Shock absorber has a serious fluid leak (2.7.3) Front Brake pad(s) less than 1.5 mm thick (3.5.1g) Exhaust emissions Lambda reading after 2nd fast idle outside specified limits (7.3.D.3) Parking brake: efficiency below requirements (3.7.B.7) Advisory notice item(s): Offside Front Shock absorber has a light misting of oil (2.7.3) Test date: 16 May 2007 Expiry date: 15 May 2008 Test Result: Pass Odometer reading: 150,975 miles MOT test number: 1824 1683 7196 Test date: 8 May 2007 Test Result: Fail Odometer reading: 150,870 miles MOT test number: 2530 8882 7472 Reason(s) for failure: Offside Rear Registration plate lamp not working (1.1.5c) Centre Exhaust has a major leak of exhaust gases (7.1.2) Offside Rear Brake hose leaking (3.6.A.1) Nearside Front Tyre has ply or cords exposed (4.1.D.1b) Emissions not tested (7.0) Brake performance not tested (3.7.A.1) Service brake: efficiency below requirements (3.7.B.7) Parking brake: efficiency below requirements (3.7.B.7) Advisory notice item(s): Nearside Rear Road wheel slightly damaged (4.2.A.1a) Test date: 13 April 2006 Expiry date: 12 April 2007 Test Result: Pass Odometer reading: 129,166 miles MOT test number: 2946 3340 6401 Advisory notice item(s): Front Tyre worn close to the legal limit (4.1.E.1) Offside Rear Exhaust has a minor leak of exhaust gases (7.1.2) Link to comment Share on other sites More sharing options...
kitch79 Posted March 30, 2016 Share Posted March 30, 2016 Boooooming Ek!! List goes on and on ha Link to comment Share on other sites More sharing options...
charlton Posted March 30, 2016 Share Posted March 30, 2016 The wife and I were laughing at this yesterday. They have other cars advertised on there too, but they have the company logo/website over the number plate, for some reason they chose not to on this one, couldn't imagine why Link to comment Share on other sites More sharing options...
Dim Sum Posted March 30, 2016 Share Posted March 30, 2016 Even my daily banger didnt get that much of advisory at this years MOT, just two tyres at limit. Damnnnnnn Link to comment Share on other sites More sharing options...
