Great advert on Autotrader
mplavery
I think it's actually a facelifted, pre...
Says its '97, it was also was imported in 97, but it's on an 'L' reg, 1993/94 year.
Worst private reg EVER!
You mean someone went through all the trouble completely facelifting it, and then it turned out like this? Even worse. :(
Registration number: L154GNY
Vehicle make: TOYOTA
Vehicle model: SUPRA
Date first used: 31 December 1993
Fuel type: Petrol
Colour: Silver
MOT history of this vehicle
Test date: 12 August 2013
Expiry date: 11 August 2014
Test Result: Pass
Odometer reading: 259,080 miles
MOT test number: 1975 2482 3218
Advisory notice item(s):
Parking brake lever has little reserve travel (3.1.6b)
Front Headlamp has a product on the light source but not seriously reducing light output (1.7.5a)
Test date: 26 July 2012
Expiry date: 11 August 2013
Test Result: Pass
Odometer reading: 241,079 miles
MOT test number: 4887 5800 2279
Offside Rear Tyre worn close to the legal limit (4.1.E.1)
Nearside Rear Anti-roll bar linkage ball joint dust cover damaged, but preventing the ingress of dirt (2.4.G.2)
Test date: 5 July 2012
Test Result: Fail
MOT test number: 3791 1708 2172
Reason(s) for failure:
Headlamp aim beam image obviously incorrect (1.8.A.1b)
Nearside Rear Anti-roll bar linkage ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.4.G.2)
Offside Rear Tyre(s) incorrect because different size tyres are fitted on the same axle. (4.1.A.1a)
Rear Upper Suspension arm has excessive play in a ball joint (2.4.G.2)
Offside Front brake disc in such a condition that it is seriously weakened (3.5.1i)
Front Headlamp aim beam image obviously incorrect (1.8.A.1b)
Front Brake pad(s) less than 1.5 mm thick (3.5.1g)
Service brake: efficiency below requirements (3.7.B.7)
Parking brake: efficiency below requirements (3.7.B.7)
Brakes imbalanced across an axle (3.7.B.5b)
Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
Offside Rear Anti-roll bar rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Rear registration plate deteriorated but not likely to be misread (6.3.1d)
rear diffirential has Rough noise
Test date: 10 August 2011
Expiry date: 11 August 2012
Test Result: Pass
Odometer reading: 225,951 kms
MOT test number: 4865 4222 1257
Test date: 8 August 2011
Test Result: Fail
MOT test number: 3986 9082 1228
Nearside Side repeater not working (1.4.A.2c)
Nearside Headlamp not working on dipped beam (1.7.5a)
Offside Rear fog lamp not working (1.3.2b)
Rear registration plate insecure (6.3.1b)
Rear Anti-roll bar fractured (2.4.G.1)
Nearside Rear Tyre has ply or cords exposed (4.1.D.1b)
Offside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Nearside Rear Mechanical brake component has restricted free movement (3.5.1k)
Nearside Front Tyre worn close to the legal limit (4.1.E.1)
Offside Front Tyre worn close to the legal limit (4.1.E.1)
Nearside Rear Upper Suspension arm has slight play in a ball joint (2.4.G.2)
Test date: 12 August 2010
Expiry date: 11 August 2011
Test Result: Pass
Odometer reading: 213,971 miles
MOT test number: 5218 9492 0299
Test date: 5 August 2009
Expiry date: 4 August 2010
Test Result: Pass
Odometer reading: 193,149 kms
MOT test number: 7333 7771 9276
Test date: 24 July 2009
Test Result: Fail
MOT test number: 3842 6500 9296
Nearside Front position lamp(s) not working (1.1.A.3b)
Offside Front position lamp(s) not working (1.1.A.3b)
Nearside Front Headlamp not in good working order adversely affecting beam image (1.2.4a)
Offside Front Headlamp not in good working order adversely affecting beam image (1.2.4a)
Nearside Registration plate lamp not illuminating the registration plate (1.1.C.1e)
Offside Registration plate lamp not illuminating the registration plate (1.1.C.1e)
Nearside Front Shock absorber has a serious fluid leak (2.7.3)
Offside Front Shock absorber has a serious fluid leak (2.7.3)
Nearside Rear Shock absorber has a serious fluid leak (2.7.3)
Nearside Front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Nearside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Nearside Front brake disc in such a condition that it is seriously weakened (3.5.1i)
Nearside Rear brake disc excessively pitted (3.5.1h)
Offside Rear brake disc excessively pitted (3.5.1h)
Test date: 4 July 2008
Expiry date: 3 July 2009
Test Result: Pass
Odometer reading: 173,214 kms
MOT test number: 6034 3658 8144
Offside Front Shock absorber has a light misting of oil (2.7.3)
Test date: 26 June 2008
Test Result: Fail
Odometer reading: 172,927 kms
MOT test number: 1247 6877 8152
Headlamp aim too high (1.8)
Offside Rear fog lamp excessively damaged so that it is not visible from a reasonable distance (1.3.2d)
Windscreen wiper does not clear the windscreen effectively (8.2.2)
Exhaust emissions Lambda reading after 2nd fast idle outside specified limits (7.3.D.3)
Test date: 16 May 2007
Expiry date: 15 May 2008
Test Result: Pass
Odometer reading: 150,975 miles
MOT test number: 1824 1683 7196
Test date: 8 May 2007
Test Result: Fail
Odometer reading: 150,870 miles
MOT test number: 2530 8882 7472
Offside Rear Registration plate lamp not working (1.1.5c)
Centre Exhaust has a major leak of exhaust gases (7.1.2)
Offside Rear Brake hose leaking (3.6.A.1)
Nearside Front Tyre has ply or cords exposed (4.1.D.1b)
Emissions not tested (7.0)
Brake performance not tested (3.7.A.1)
Nearside Rear Road wheel slightly damaged (4.2.A.1a)
Test date: 13 April 2006
Expiry date: 12 April 2007
Test Result: Pass
Odometer reading: 129,166 miles
MOT test number: 2946 3340 6401
Offside Rear Exhaust has a minor leak of exhaust gases (7.1.2)
