pedrosixfour Posted March 29, 2016 Share Posted March 29, 2016 Thoughts on this particular turbo fitted to a 1JZ/R154? Only real changes to the engine would be 264° BC cams, standalone, adequate fuelling & cooling. Pointless, as in too big, even for track use only? Quote Link to comment Share on other sites More sharing options...
Luxluc Posted March 29, 2016 Share Posted March 29, 2016 What power would you push it up to? Quote Link to comment Share on other sites More sharing options...
Hemanhead Posted March 29, 2016 Share Posted March 29, 2016 I thought the T51r Kai was the smaller turbo, the SPL being the big boy. That said, it's pretty old tech so I assume you will be buying it for the sound ? Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted March 29, 2016 Author Share Posted March 29, 2016 Wouldn't really be chasing huge numbers Luc, the rest of my drivetrain would more than likely start suffering at the kind of power and torque figures the Getrags and matched diffs are used to seeing. If I said an upper limit of 600-650bhp is all I would ever need from a turbo. There are no big power circuits here in Ireland, my car is geared to 155mph flat out and even with 1000hp I'd never see that speed at the tracks here. A big dollop of mid-range "oomph" would serve me better I think. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted March 29, 2016 Author Share Posted March 29, 2016 I thought the T51r Kai was the smaller turbo, the SPL being the big boy. That said, it's pretty old tech so I assume you will be buying it for the sound ? Never realised the T51R had such a cult status for the sound alone, until I started doing a bit of searching. My list of priorities wouldn't include the noise it makes TBH. No, the reason this particular snail popped onto my radar is because it is part of a 1JZ specific kit that is for sale here in Ireland. 1JZ manifolds aren't as common as the 2JZ equivalents, so when one does present itself as part of a single kit I try to take a measured look at the consequences of buying said kit. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted March 29, 2016 Share Posted March 29, 2016 Damien where did you get a T51R! I would like to get one just for the noise, glorious! Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted March 29, 2016 Author Share Posted March 29, 2016 Damien where did you get a T51R! I would like to get one just for the noise, glorious! I didn't get anything yet Carlo. Trying to approach this logically! Quote Link to comment Share on other sites More sharing options...
Jellybean Posted March 29, 2016 Share Posted March 29, 2016 Ah Ok, they are like hens teeth; the 62R is the holy grail of HKS series Might be worth looking into the fitment, I think it might be a VBand setup , HKS and 6Boost as far as I am aware only make manifolds with a VBand fitment for the 2JZ but I am sure a member on here with one can clarify Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted March 29, 2016 Author Share Posted March 29, 2016 (edited) Ah Ok, they are like hens teeth; the 62R is the holy grail of HKS series Might be worth looking into the fitment, I think it might be a VBand setup , HKS and 6Boost as far as I am aware only make manifolds with a VBand fitment for the 2JZ but I am sure a member on here with one can clarify It's a VBand mounted turbo alright, comes with a HKS manifold too, apparently. But, looking at a picture of the set-up, the mount looks a bit like an add-on. I'd imagine the VBand mount fairly limits the choice of other turbos that can be used with the manifold? Edited March 29, 2016 by pedrosixfour (see edit history) Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted March 29, 2016 Author Share Posted March 29, 2016 See what I mean? Quote Link to comment Share on other sites More sharing options...
Jellybean Posted March 29, 2016 Share Posted March 29, 2016 It's a VBand mounted turbo alright, comes with a HKS manifold too, apparently. But, looking at a picture of the set-up, the mount looks a bit like an add-on. I'd imagine the VBand mount fairly limits the choice of other turbos that can be used with the manifold? Looks a bit odd alright , Tial do Vband Stainless Steel housing so in theory you could make any Turbo Vband fitment ; Owen Developments use it alot Quote Link to comment Share on other sites More sharing options...
Luxluc Posted March 29, 2016 Share Posted March 29, 2016 The T51 is a 72mm turbo iirc. If my goal would be a track built Supra with your specs and power goals, I would go for a smaller turbo .... my personal choice would be a Gen2. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted March 29, 2016 Author Share Posted March 29, 2016 Looks a bit odd alright , Tial do Vband Stainless Steel housing so in theory you could make any Turbo Vband fitment ; Owen Developments use it alot Got a few more pictures sent over to me. Really not as keen on it now, the manifold was definitely a bolt-on type mount before, but a VBand mount was welded in place on top of that and the T-type mount was ground back to match the outside diameter, so the turbo would be sitting higher than it should on the correct manifold, which could be a problem. The T51 is a 72mm turbo iirc. If my goal would be a track built Supra with your specs and power goals, I would go for a smaller turbo .... my personal choice would be a Gen2. I'll keep looking so Luc. I don't really fancy a turbo that only comes to life at 6k rpm and then tries to kill me before the redline! Thanks for the input one & all. Quote Link to comment Share on other sites More sharing options...
