Slip control light
K22SUP
Hi guys see if anyone can shed any light what happened this morning while slip control was off I had the tail out 1st second gear immediately parked up slip control was flashing when I went to select reverse car didn't move would drive forward switched it off on couple times it selected reverse and light went out just wondering if it's an issue or has anyone had it before and what is the cause thanks edd
  • 7 months later...
My Slip Control Light was on after having fitted a New Baattery nearly 3 months ago:
it hasnt been anywhere since, other than on the drive.
Today a totally 'flat' battery as its not been driven.
Anyway after jump starting it I drove it for some 14 miles but the Slip Control Light stayed flashing.
I read this thread on the forum and realised that I didnt turn the ignition off, nor did I try reversing the car.
Now been out and restarted the car,
Success! No more Slip Cntrl Light flashing and everything is in order. Must be down to restarting the ignition to reset the system. Thanks Members for this tip!. :)
