Air Con Cleaner
a98pmalcolm
  • 3 months later...
What do these do exactly, is it just clean away bad smells? Does it help make it colder in anyway?
Also, anyone know the best way to clear out the brown insulation that sometimes fires through the vents, or the odd leaf that gets stuck in there?
No I used the Normfest stuff, one which you spray down the vents and also the one you set off in the passenger footwell then let it run on cabin circulation for 10-15 minutes.
Probably didn't have to do both but they were cheap so I thought I might aswell!
