AEM Infinity
Jellybean
That's the route I'm taking in the next month or two.
Lots of decent hardware upgrades from the series 2. Loving the can bus BTi gauge which is much like the toucan for the syvecs.
That's the route I'm going. I believe a custom loom is currently required.
I'm NA-try though so GTE might be okay.
I wish there was a 52mm syvecs gauge setup. I don't really want a big 'ol toucan on my dash, but as I want the info available I may be forced into it!
I thought the same, but honestly the Toucan is much smaller than you expect. I've managed to integrate mine well into the dash :)
Much more oem looking than gauges :)
http://i297.photobucket.com/albums/mm203/j_s14a/Snoopy%20Supra/DSC_0141_zps5mjgxk9b.jpg
I must admit that's the first toucan I've seen that looks ok, colour matches the dash panels very well.
Usually they look a right eye sore.
Didnt you fit yours then did a right up about how good it was then the mods got funny with the thread cos it looked like a sales pitch I cluld have swore it was somthing like that
Yeah, I did a write up as it was and still is a brilliant ECU so I stand by that. Regarding mods getting funny, this is the first time I'm hearing this :confused:
Funny how it sounded like a sales pitch, as I never offered or tried to sell one. My career isn't in cars or ECU's.
How you finding it GPro , Did I read on Supra Forums members had an issue when it was launched with Idle on cold start up bit I think it was since fixed with a firmware update
Just reading up about it I think it just needs a Map sensor and the Fuel / Oil pressure are extra's for the fail safes , maybe a Bosch LSU
What did you get in the kit? ECU and Mkiv Loom?
I dont think it will control the stock twin sequential turbos , I will need to go TTC
My kit came with Mkiv PnP harness, map sensor, fuel pressure sensor, boost solenoid, air intake temp sensor, 12 position switch and wideband sensor.
At a minimum you would need the wideband/Bosch sensor, the ECU can work with your stock map sensor. Fuel pressure is optional, but highly recommended for accurate close loop.
Latest firmware seems to be stable, as far as I'm aware.
This is the package I got. http://fsrmotorsports.com/component/virtuemart/?page=shop.product_details&flypage=flypage.tpl&product_id=19&category_id=20&Itemid=87
but, this cheaper package should be fine for most users. http://fsrmotorsports.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=257&category_id=20&Itemid=87&vmcchk=1&option=com_virtuemart&Itemid=87
Edited by Gpro (see edit history)
Thanks , the ECU did catch my eye when it was launched but it does not seem to be popular here across the board in the EU for some reason , few skylines etc run them
Spec wise it does seem to be great value , is there any cool apps, software , gadgets you can use with it?
If the AEM gauge is CAN based it could prob be made to work with a Syvecs ;)
EDIT: same goes for the gaugeArt :D
How did I never know about this previously!!!! I need this in my life!!! I'm 100% going this route with my infinity.
I need a new head unit anyway. That's top notch
