TT auto box flywheel help
shervin_ice
Hi all
Im doin my 5th supra na/tt transplant ,i recently purched an tt engine which had w58 manual gearbox conversion on it but im planing to use my auto gearbox the question is can i use the same flywheel it came with w58 or do i have to change it to auto flywheel ,? I know r154 and 6speed flywheel are diffrent to auto box flywheel but not too sure about the auto and w58 ,could anyone help me to get this right please
Thanks
Edited by shervin_ice (see edit history)
Manual flywheels and clutches are horses & carriages, you need a flex-plate & torque-converter compatible with the automatic transmission.
Note that an N/A box won't take T.T. power and a T.T. box won't work with N/A ECU.
Check out the link in my signature for more info.
Manual flywheels and clutches are horses & carriages, you need a flex-plate & torque-converter compatible with the transmission.
Im using the tt auto box and i do have torque converter on it already just wanted to know if the flywheel are the same as w58 ,so really i need a tt auto flywheel (flex-plate) or can i just use a na flywheel or is it too weak for tt?
