Sheefa Posted March 22, 2016 Share Posted March 22, 2016 (edited) Hi all As some of you may know I was made redundant after 10 years in my job (I preferenced it so all good) and am going to be leaving the company this Thursday (gardening leave for 1 month too). So, today I decided to have one of my very last "WFH" days with current employer and it was as productive as ever........ I'll miss them days.... The front lip on my car, Whifbitz one I think, was looking pretty damn tired and chipped to hell so I decided a refurb was in order. I hadn't tried plastidip before and read mixed reviews, however given its durable nature and rubber like coating I thought I'd give it a whirl. I have to say I am mega impressed. It's come out an absolute treat after 4 coats (30mins between each) and a final thick coat left for 4 hours to cure. We'll see how long it lasts but as I said very happy with the Matt finish. Pics of the prep and final outcome are below. I also managed to finish painting my rear Calipers with the Foliatec brake paint in Carbon grey. This stuff is awesome and looks like OEM finish and is really easy to apply. Decals also applied. Now sitting pretty, although I have purchased new front and rear UK OEM discs and Porterfield Street pads which I shall install next week with the help of Glanza_Mike to finish off the setup Big difference! Then a little OCD has grown on me by a fellow supra owner so I began cleaning up the front bumper chassis area behind the Intercooler plate, no photos of how bad it was but trust me it was dirtier than Britney Spears in her prime. Now all cleaned up Also managed to fit a new aux/fan belt as my one has some chaff-age, albeit quite cosmetic and must of been caused by debris in a pulley or something. I then gave some of the chrome bits and piping a good polish. Thanks to Rob Mitchell for recommending that Kleers! That stuff is awesome That's it for now. Got quite a few things to do before the car goes to SRD in the next month. Cheers Greg Edited March 22, 2016 by Sheefa (see edit history) Quote Link to comment Share on other sites More sharing options...
sidewaysdan Posted March 22, 2016 Share Posted March 22, 2016 Front lip looks very good thinking of spraying mine soon. Good job Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted March 22, 2016 Share Posted March 22, 2016 Lip looks great mate The good thing with Plastidip is that if you end up with a few more chips, you can just spray a bit more over without needing to mask it up, and just rub off the excess. Quote Link to comment Share on other sites More sharing options...
Sheefa Posted March 22, 2016 Author Share Posted March 22, 2016 (edited) Lip looks great mate The good thing with Plastidip is that if you end up with a few more chips, you can just spray a bit more over without needing to mask it up, and just rub off the excess. Exactly Jason, really easy to apply and the drying time is damn quick! As always prep is everything and I washed the lip a few times, then went over it with Meguairs all purpose cleaner and finally alcohol wipes. Made the whole application a lot easier and smoother! Thanks mate Edited March 22, 2016 by Sheefa (see edit history) Quote Link to comment Share on other sites More sharing options...
peter richards Posted March 22, 2016 Share Posted March 22, 2016 well done mate Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted March 22, 2016 Share Posted March 22, 2016 I did the same on my APR carbon rad plate, makes it look like a stock item in plastidip although I can probably get away with the carbon now I'm single turbo Quote Link to comment Share on other sites More sharing options...
Glanza_Mike Posted March 22, 2016 Share Posted March 22, 2016 I'm glad my ocd is rubbing off on you mate looks great Quote Link to comment Share on other sites More sharing options...
SupraP-Z Posted March 23, 2016 Share Posted March 23, 2016 These little tidy ups make the world of difference! What did you use to clean up the slam panel area and side bits where the wing bolts onto? Mine are absolutely filthy as well. Looks like you've done a pukker job Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted March 23, 2016 Share Posted March 23, 2016 I may have missed this but did you uses primer? i made the mistake of not doing and it peeled. if you used primer then it will definitely last Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted March 23, 2016 Share Posted March 23, 2016 Looks great. I'm really not a fan of plastidip but it does have its uses, and it has stood the test of time on my centre caps, over the last couple of years. Looks great on the lip. Great work Quote Link to comment Share on other sites More sharing options...
jim Posted March 23, 2016 Share Posted March 23, 2016 That's given me a bit of motivation to get out and spend some time cleaning my bay over the easter weekend looks great Greg Quote Link to comment Share on other sites More sharing options...
MATT RR Posted March 23, 2016 Share Posted March 23, 2016 great job, lip looks great as do the breaks Quote Link to comment Share on other sites More sharing options...
Al Massey Posted March 23, 2016 Share Posted March 23, 2016 I may have missed this but did you uses primer? i made the mistake of not doing and it peeled. if you used primer then it will definitely last You don't use primer with plastidip Quote Link to comment Share on other sites More sharing options...
kitch79 Posted March 23, 2016 Share Posted March 23, 2016 You don't use primer with plastidip I think your meant to. Quote Link to comment Share on other sites More sharing options...
Al Massey Posted March 23, 2016 Share Posted March 23, 2016 I think your meant to. [ATTACH]210293[/ATTACH] You don't need it, it helps on certain surfaces but I've never had a problem in all my work Quote Link to comment Share on other sites More sharing options...
Marcus GTE Posted March 23, 2016 Share Posted March 23, 2016 Looks like a productive day! Quote Link to comment Share on other sites More sharing options...
Sharpie Posted March 23, 2016 Share Posted March 23, 2016 Looks great! Quote Link to comment Share on other sites More sharing options...
Sheefa Posted March 23, 2016 Author Share Posted March 23, 2016 These little tidy ups make the world of difference! What did you use to clean up the slam panel area and side bits where the wing bolts onto? Mine are absolutely filthy as well. Looks like you've done a pukker job Thanks mate. I used Meguiars All Purpose Cleaner and Brake Cleaner, then the Kleers metal/chrome polish on the shiny bits. All came up a treat. I'm glad my ocd is rubbing off on you mate looks great It sure is! well done mate Thanks bud. Hope you're well? I may have missed this but did you uses primer? i made the mistake of not doing and it peeled. if you used primer then it will definitely last No primer needed mate as far as I can tell and from previous threads etc. I'll see how it lasts over the next few months after some hard driving Looks great. I'm really not a fan of plastidip but it does have its uses, and it has stood the test of time on my centre caps, over the last couple of years. Looks great on the lip. Great work Thanks Jake. That's given me a bit of motivation to get out and spend some time cleaning my bay over the easter weekend looks great Greg Cheers Jim, it's not bad weather for it hopefully either! Highly recommend the Kleers stuff. great job, lip looks great as do the breaks Cheers Matt. You don't use primer with plastidip Exactly, came out perfect on mine and will see how long the finish lasts. Looks like a productive day! Looks great! A tough days work gentlemen indeed! Thanks. Quote Link to comment Share on other sites More sharing options...
Burna Posted March 23, 2016 Share Posted March 23, 2016 Looks good mate. Quote Link to comment Share on other sites More sharing options...
Hammer Posted March 23, 2016 Share Posted March 23, 2016 Looking good and all being paid for by someone else, win, win Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted March 23, 2016 Share Posted March 23, 2016 nice one bud Quote Link to comment Share on other sites More sharing options...
