suprapower13 Posted March 12, 2016 Share Posted March 12, 2016 Na-t build anything missing any suggestions?? Supra turbo list Turbo Exhaust manifold Down Pipe Wastegate/dump tube Oil feed/return lines Intake pipe Intercooler Intake manifold Gaskets 255 fuel pump Wideband Pulley set Cam pulleys Oil drain plug Head gasket Head studs Blow off valve Need----- Throttle body Throttle cable Intercooler piping Stand alone Injectors Spark plugs Boost gauge Timing belt Drill/tap oil pan Relocate power steering res Drill tap oil feed bolt Tune I also just finsihed my auto to r154 swap but seem to not get speed on speedo, i did the w58 gear sensor Link to comment Share on other sites More sharing options...
Nic Posted March 12, 2016 Share Posted March 12, 2016 (edited) Air filter BOV weld on flange. Turbo blanket? OEM crank pulley? Cambelt tensioner and idler pulley Auxiliary belt and tensioner? Oil pump? Water pump? Fuel filter? Distributer cap and rotor arm? Oil & oil filter Coolant New valve stem seals whilst you have the head off? Toyota do a gasket/seal kit which includes everything you'll need. Edited March 12, 2016 by Nic (see edit history) Link to comment Share on other sites More sharing options...
suprapower13 Posted March 14, 2016 Author Share Posted March 14, 2016 i have a 4 runner cap to get the wires out the way of the turbo forgot to post that and i have to locate a filter thank you for the input so in other words you are saying a engine rebuild to top it all off?? Link to comment Share on other sites More sharing options...
Parm_93 Posted March 14, 2016 Share Posted March 14, 2016 I have a GE fully refreshed cylinder head perfect for this build, all machine work done and everything that needs replacing done. I also have a new MLS head-gasket and ARP head bolts. Let me know if that's any good to you. http://www.mkivsupra.net/vbb/showthread.php?331673-2JZGE-Fully-Refreshed-Cylinder-Head Link to comment Share on other sites More sharing options...
Style Posted March 14, 2016 Share Posted March 14, 2016 Mid-pipe as well Link to comment Share on other sites More sharing options...
suprapower13 Posted March 14, 2016 Author Share Posted March 14, 2016 thank you but i live in canada and the exchange rate and shipping would be way to much and yea i will be looking for a mid pipe Link to comment Share on other sites More sharing options...
