Jellybean Posted March 10, 2016 Share Posted March 10, 2016 (edited) Search but could not find an answer , is this just a straight drop in or is there an issue with the 2jzgte sump hitting subframe ect? Anything needs modding or swapping with the 2JZGE? Would an Aristo 2JZGTE have its own set of problems versus a MK4 2JZGTE ? Edited March 10, 2016 by Jellybean (see edit history) Quote Link to comment Share on other sites More sharing options...
trebor69 Posted March 10, 2016 Share Posted March 10, 2016 (edited) AFAIK you just need the engine loom and ecu too.....as long as its not from an Aristo. You would then want to consider brakes and suspension oh and there is a rev counter mod too. Downpipe will differ from an N/A, you need igniter, I/C and power steering res. Aristo GTE differs a lot, do a search as it's been asked before (recently too). Edited March 10, 2016 by trebor69 (see edit history) Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted March 11, 2016 Share Posted March 11, 2016 http://www.mkivsupra.net/vbb/showthread.php?136136-NA-to-TT-engine-transplant-step-by-step-guide-(Pic-heavy) All the info you need including parts list is in that thread. If you're fitting the 2JZ GTE engine from an Aristo into a Supra then you will need to change the sump as it catches on the subframe. A TT engine from a Supra will be a straight fit. Quote Link to comment Share on other sites More sharing options...
HELLBOY666 Posted March 11, 2016 Share Posted March 11, 2016 (edited) Good info on that Edited March 11, 2016 by HELLBOY666 (see edit history) Quote Link to comment Share on other sites More sharing options...
HELLBOY666 Posted March 11, 2016 Share Posted March 11, 2016 (edited) So would a 1jz tt fit straight into n/a auto box??? Edited March 11, 2016 by HELLBOY666 (see edit history) Quote Link to comment Share on other sites More sharing options...
trebor69 Posted March 11, 2016 Share Posted March 11, 2016 Yes the n/a box fits the 1jz. Quote Link to comment Share on other sites More sharing options...
