Lower Rad Pipe Question
a98pmalcolm
Hey all.
I've had a silicone lower rad pipe for well over 5 years now. I replaced my TT lower neck for an NA one some months back now (there a little shorter)
I have a leak from the lower rad pipe (water neck side) and even after making sure the pipe is seated correctly I'm still having a small leak. With the pipe being a cheap ebay job I think I should replace it, especially now I'm running a lot more power than stock.
My question is, is the water pump situated in the same place on an NA to a TT if so would it be worth looking at a decent NA lower pipe? Or just stick with a TT one?
Thanks
Paul
