Driftmotion/marlin crawler R154 full conversion to mk4
Sanya.kiss83
For Sale:
Driftmotion/Marlin Crawler R154
It's a full conversion to mk4 with OEM jz bellhousing, shifter extension, prop shaft, clutch/flywheel/throwout bearing.
Box: low mileage box with all new bearings, seals, upgraded synchros for faster upshifting, heavy duty bearing retainer, heavy duty thrust washer, MC shifter bushings, electric speed sensor.
Shifter extension to fit mk4
2jz 5.5kg high quality flywheel with AP Racing kevlar twin disc clutch / Southwest speed racing throwout bearing.
Modified propshaft to fit mk4
All these parts + the box cost me over £3000 so no stupid offers pls. Like £1500. The clutch kit cost over £1000 from usa
The box can handle about 800hp
The clutch kit good up to 900Nm
About 2000km in the whole kit.
If you have any question pm me or email me to [email protected]
Price: £2499 or best offer
Okay couple questions please.
Can't see the clutch make. What is it. Is that a twin plate clutch? Ignore that; "AP Racing kevlar twin disc clutch" just seen it!
Not picking, but it says here it's rated to 842NM (https://www.apracing.com/product_details/race_car/metallic_race_clutches/%C3%B8215mm_types/twin_plate_cp5242_family.aspx)
How was the prop modified, was it just split by knocking the pin out.
Electric speed sensor on the box, is this just an OEM swap. Is it the same signal output as the mkiv. I can't remember what I done on my R154 but it came with the correct speed sensor.
Did you have the upgraded shifters inside the box from the MC kit as well?
I'm just about to rebuild and upgrade my R154. So I may go this route instead, and have myself a spare.
Due to already have bought an R154 (overpriced due to have to rebuild it), new clutch and all that bollocks I'd want to haggle. Obviously not suck the price to be rude.
Does it come with the correct clutch fork assembly? I have a brand new pull setup, but most higher performance clutches have a push. Though I do have this also, it's not new. So just want to know what I need to run that clutch please.
Yes, on the ap racing website it's rated to 848Nm , it has assembled and tested in a professional mechanic shop and it hold over 900Nm .
The prop has been shortened by an 1" if I remember well, the guy who made me the shifter extension, made the prop as well.
No billet shift forks in the box as I never use my car for drifting so no superfast shifting required.
No clutch fork included as the cluch is push type.[ATTACH=CONFIG]209992[/ATTACH] hydraulic throwout bearing included. Pm me for better pics
What diff is it made to suit. My prop goes into an NA lsd a01b
Will send you a pm now
- - - Updated - - -
