Which radiator to go for (OEM replacement)
Homer
There are so many feedbacks on different products and I'm now completely confused as to what to use a replacement radiator ('Large', manual rad). The stock ones are hugely expensive but so many of the aftermarket ones have terrible feedback, I don't mind paying good money for something non OEM but simply cannot pay out for the OEM one (it's half the price of an NA Supra). I'm not really willing to compromise with OEM fit for the shroud, OEM caps, sensors, etc.
Are there any tried and tested OEM replacements available out there that fit & perform as well as Toyota made - but without the Toyo premium?
My mishimoto had a very small leak around the neck weld. I have had 3 koyo's fit like stock used with the stock shroud viscous fan and perk fan even has the nut on the top for the stock air box plastic intake never had a problem used a stant rad cap standard pressure
Thanks for the feedback gents :thumbs:
So it's the Koyo or Moshimoto?
- Are they the thicker size rad?
- Stock fan shroud fits as it's intended?
- Do they use the stock fitments for the sensors, etc?
- Stock rad cap fits okay?
Presumably these are alu and not copper... which will explain the price difference :)
TIA!
I have a tt6 oem rad in perfect working order sat here doing nothing. You can have it for a beer voucher if it helps you. I only changed it for a mishimoto one as I wanted new everything.
That's very kind of you! However I'm probably the same as you and want new everything (at least when it comes to replacing things), thanks all the same, much appreciated :thumbs:
