Richie_k83 Posted November 17, 2016 Share Posted November 17, 2016 Good to see so much Positive feedback on this Link Stuff... I was looking at the PnP one for my Throttle Body install for simplicity, seem good bang for buck. Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted November 17, 2016 Share Posted November 17, 2016 Link ECU's are awesome. Quote Link to comment Share on other sites More sharing options...
berg Posted November 17, 2016 Share Posted November 17, 2016 Just had my G4+ mapped on my car Superb bit of kit, has all the fail safe functions using the sensors, Toucan display all setup to it too Well happy i went for it Only downside to some is it doesnt control an autobox Quote Link to comment Share on other sites More sharing options...
mkivtt Posted November 24, 2016 Share Posted November 24, 2016 Do you mind telling us who installed and mapped it please? I do like the Link software, from the point of view of ease of use and clarity of function. Hi Chris, I am from Australia/Malaysia so yeah the car was mapped by JPC.com.au in Melbourne, Australia. The car is now in Malaysia. It is really good ecu but i do find it slow in releasing new stuff vs other brands. Quote Link to comment Share on other sites More sharing options...
mkivtt Posted November 24, 2016 Share Posted November 24, 2016 Just had my G4+ mapped on my car Superb bit of kit, has all the fail safe functions using the sensors, Toucan display all setup to it too Well happy i went for it Only downside to some is it doesnt control an autobox great to see if linkecu support autobox out of the box... or at least having support for autobox. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted November 24, 2016 Share Posted November 24, 2016 So, is the Kurofune ECU able to run the sequential stock twins? Knock control from the stock sensors? Any other sensors needed? http://www.linkecu.com/products/wirein-ecus/g4-kurofune/ Quote Link to comment Share on other sites More sharing options...
np89 Posted November 24, 2016 Share Posted November 24, 2016 So, is the Kurofune ECU able to run the sequential stock twins? Knock control from the stock sensors? Any other sensors needed? http://www.linkecu.com/products/wirein-ecus/g4-kurofune/ Yes it is able to run the car as stock - source, direct from Link UK & Ireland regional manager Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted November 24, 2016 Share Posted November 24, 2016 Thanks mate.. So it's a standalone that runs as a piggyback just as the FCon does? Of course with much more features.. Quote Link to comment Share on other sites More sharing options...
np89 Posted November 24, 2016 Share Posted November 24, 2016 Thanks mate.. So it's a standalone that runs as a piggyback just as the FCon does? Of course with much more features.. Yea essentially. Only thing the stock ecu controls is the turbos as far as i understand Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted November 25, 2016 Share Posted November 25, 2016 I had a TT running on the old G3 XLEM donkey's ago in full sequential. If you piggyback them they work with the autobox just fine. You just need to know what to take control of and what to leave to the stock ecu. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted November 25, 2016 Share Posted November 25, 2016 Only things I need to confirm is can a wideband 02 sensor be connected to the Kurofune and does it pull timing when it detects knock.. Quote Link to comment Share on other sites More sharing options...
mkivtt Posted November 27, 2016 Share Posted November 27, 2016 Yes, wideband can be connected, and yes knock detection works well as long as you have the sensor calibrated properly for your engine. You could actually download latest copy of the link software and load up kurofune's sample map and you can see all the features that are supported. I wish Thunder also have analog volts out like in Kurofune !!!! Link should have done this ahead of other ecu....hmm.. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted November 27, 2016 Share Posted November 27, 2016 Yes, wideband can be connected, and yes knock detection works well as long as you have the sensor calibrated properly for your engine. You could actually download latest copy of the link software and load up kurofune's sample map and you can see all the features that are supported. I wish Thunder also have analog volts out like in Kurofune !!!! Link should have done this ahead of other ecu....hmm.. Thanks mate. Will do that. Quote Link to comment Share on other sites More sharing options...
wrighty338 Posted November 29, 2016 Share Posted November 29, 2016 Very interesting thread guys top stuff. Do they do an off the shelf ECU for the later VVTI supras? Quote Link to comment Share on other sites More sharing options...
V8KILR Posted November 29, 2016 Share Posted November 29, 2016 Very interesting thread guys top stuff. Do they do an off the shelf ECU for the later VVTI supras? Unfortunately there is no plug-in for the VVTi Supra's. However, all of the wire-in Link G4+ range can run the VVTi. Quote Link to comment Share on other sites More sharing options...
np89 Posted November 29, 2016 Share Posted November 29, 2016 Unfortunately there is no plug-in for the VVTi Supra's. However, all of the wire-in Link G4+ range can run the VVTi. Yea, and is a great opportunity to do away with alot of the 20yr old wiring and have a real trick custom loom!! Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted November 29, 2016 Share Posted November 29, 2016 Anyone know how I would handle the speed limit & boost limit if I keep the stock ECU & run the Kurofune? Quote Link to comment Share on other sites More sharing options...
mkivtt Posted December 10, 2016 Share Posted December 10, 2016 (edited) Very interesting thread guys top stuff. Do they do an off the shelf ECU for the later VVTI supras? They used to have pnp adapter box back then and i am actually still running that adapter to date but now with newer Thunder ecu(upgrade from vipec v88). I just don't understand why they drop that product. Edited December 10, 2016 by mkivtt (see edit history) Quote Link to comment Share on other sites More sharing options...
martincoupe Posted December 11, 2016 Share Posted December 11, 2016 I'm in the process of making adaptors so will update you in the future just waiting for plugs Quote Link to comment Share on other sites More sharing options...
