BPU+ On UK-Spec
Big Supes
Depends what power you are after. Max duty cycle 80-85% so on 550cc injectors you'll be near max limit at circa 450bhp. Worth getting some drop in 650 or 850 injectors. Cams will be fine.
Thanks Sheefa. For the sake of dropping in some bigger injectors, I guess it makes sense.
What hybrids you going with mate im looking into them too
Just putting the feelers out at the moment. With swopping out the injectors & resistor pack, aftermarket ECU, I may consider a small single set up. It will probably be determined by what is out there at the time.
