Rear quarter Glass Color
Jellybean
thanks Nic , when I get the car back will check but nearly sure it has a blueish tint
Just thinking if it will look odd with the Green window, is the rear window tinted too?
All the windows are tinted, the tint is very subtle but you can see the difference when you put a facelift and pre-facelift Supra together. If you check the EPC there are different part numbers for the blue and green glass, it's in Japanese but if you translate it you'll see which is which.
