IPT modified TT auto box valve body
jumpbike
I sent my valve body state side to be reworked by IPT.
The modifications increase the oil flow and pressure inside the box allowing a higher clutch clamping force and increased shift speed all to increase the logitivity of the box under higher power applications.
My engine is swapped into a land cruiser and the shifts are too firm for it having a separate body and chassis etc. It's more suited to cars driven a bit more spirited or maybe do the occasional run up the strip but want to keep their auto.
It has done about 150 miles from being modified on a freshly rebuilt box and was removed last weekend. It is currently covered up to keep it clean.
It cost me an arm and a leg to have done plus the postage to and from the states, including import fees which I for some reason had to pay even though it was already my own property.
I am asking £350
Thanks,
  • 2 weeks later...
  • 2 weeks later...
  • 11 months later...
  • 3 weeks later...
Hi jumpbike,
From which model year Supra is coming the valve body?
As far as I am aware, there are different types valve bodies in A340e transmissions and I am not sure if they are interchangable.
Thank you.
  • 4 weeks later...
  • 2 weeks later...
  • 2 weeks later...
