kevin smith Posted February 23, 2016 Share Posted February 23, 2016 Has anyone fitted a new auto gear knob, I need advice on the O/D wire is there a clip in the wire to undo it, or do you have to cut it. Thanks Kevin. Quote Link to comment Share on other sites More sharing options...
GTR Fever Posted February 24, 2016 Share Posted February 24, 2016 I want a new knob but don't know where to get it or how to change it Also won't mind a new e-brake handle *in for advice on how to remove Quote Link to comment Share on other sites More sharing options...
evinX Posted February 24, 2016 Share Posted February 24, 2016 With the O/D button, cut the 2 wires, i tried to strip mine down and it exploded into millions of peices with the spring shooting out. Just cut and solder back on to avoid buying a used unit to salvage the od button. Changing the auto shifter is simple once you bugger it up and go back at it like i did, the button surround pops out. There is a cover at the bottom of the shifter that pushes down revealing 2 screws. The shifter lifts up and cut the od wiring. With the cover at the bottom ive seen many including mine that dont want to go back on. I dabbed a bit of araldite (expoxy) inside it and held it in place and left to dry. Be neat with it, use masking tape to cover surroundings. And job done. With the e-brake, remove the auto shifter and centre console. And for mine i needed a 17 and 19mm spanner for the 2 bolts, 10mm for the cable to loosen and then some movement of the cable to pull it of. All easy if you take your time to figure out how it all comes off. Quote Link to comment Share on other sites More sharing options...
rider Posted February 24, 2016 Share Posted February 24, 2016 From another forum - nothing to do with me just supplied for info. You need to pull down the plastic ring around the base of the shift knob, that should reveal a set of Phillips head screws which needs to be removed. Once they are undone, you should be able to remove the auto shift knob. Just watch out when you are pulling it upwards as the OD button will still be wired up and you may need to cut the wires to get the knob off completely. Quote Link to comment Share on other sites More sharing options...
Nic Posted February 24, 2016 Share Posted February 24, 2016 I want a new knob but don't know where to get it or how to change it Also won't mind a new e-brake handle *in for advice on how to remove http://www.mkivsupra.net/vbb/showthread.php?330992-supra-auto-gearstick-and-handbrake&p=4117230&viewfull=1#post4117230 Quote Link to comment Share on other sites More sharing options...
kevin smith Posted February 25, 2016 Author Share Posted February 25, 2016 Thank you. Quote Link to comment Share on other sites More sharing options...
