Suprakeith Posted February 14, 2016 Share Posted February 14, 2016 Right will start at the beginning put supra in garage around Christmas time as was all running fine, few weeks later went out to start her and nothing I suspected battery but charged and checked volts and all fine. Thought could be ignition switch so checked that and again all fine. So purchased new starter motor to eliminate that. Removed old starter motor today and spotted that the wire that goes from starter wiring loom to switch on side of engine block has snapped so believe that's why car wasn't starting. Can't get the switch out block or the connector off due to where it is and not having good access, was hoping to get it off so could re-wire and fit new starter motor to get her running. Am after if anyone else has had problem and managed to remove connector or switch and advice please and any pictures or the name and part number so can order new one. It has a 29mm nut I believe and sits bout inch under inlet manifold in the side of block. Hopefully have put down enough information for bit of help, can't really get picture of it but if needed can take picture of the damaged wire to help with any help Thank you in advance just want to get this sorted asap so supra can get ready to have bumpers painted and get her back on road Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted February 14, 2016 Author Share Posted February 14, 2016 Been told it's a knock sensor would that make sense as it's wired into ignition loom, can anyone shed any information please as really want to get car fixed as soon as Quote Link to comment Share on other sites More sharing options...
supra matt Posted February 14, 2016 Share Posted February 14, 2016 Hi mate yes sounds like a knock sencor but that won't stop the car starting! When you turn the key what happens? Does it do anything at all? It still could be your battery is flat you need to take the voltage when you are trying to start it as it could still show 12v with no load been drawn. Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted February 14, 2016 Author Share Posted February 14, 2016 Thank you and when turned key, just heard a click noise, did try jump starting her and another battery and all same that's why purchased new starter motor as think the solenoid my be faulty. My main worry now is the knock sensor wire as looks like the connector corroded and the wire has come out of it. Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted February 14, 2016 Author Share Posted February 14, 2016 Also could someone please tell me the size of socket needed to remove the knock sensor, just want to make sure use right size and can't seem to find the size is the two guides have read just tells me needs to be deep socket Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted February 17, 2016 Author Share Posted February 17, 2016 Bit of update managed to get knock sensor out and connector off. The connector is bit damaged does anyone know if can new one and part number please or if not have one spare Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 18, 2016 Share Posted February 18, 2016 http://www.mkivsupra.net/vbb/showthread.php?232824-J-Spec-Engine-Harness-Connector-Details Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted February 18, 2016 Author Share Posted February 18, 2016 Wicked thank you for that Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 18, 2016 Share Posted February 18, 2016 Wicked thank you for that Thank Andy Blyth, one of the most useful posts ever made, looking them up amongst the many hundreds of shell shapes must have taken hours and hours. Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted February 18, 2016 Author Share Posted February 18, 2016 Andy Blyth is a legend the time he must of spent doing all that thread. Thanks to have him have managed to order parts needed from Toyota for £15 and they will turn up Tuesday. Perfect result Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted March 5, 2016 Author Share Posted March 5, 2016 Well finally had time to fit new starter motor today and still no joy starting supra, when try just get a click noise and that's it, and then when turn key sometimes no dash lights come on so think must be electrical fault have checked all fuses and can't find any faulty ones. So if anyone has any ideas or knows of good garage in east anglia area please let me know as I need to get supra running soon and am out of my depth Quote Link to comment Share on other sites More sharing options...
