Just a couple of questions...............
Guest SCOOBYKILLA
Guest SCOOBYKILLA
Hey guys I recently bought a very rough bodied supra rz 94 to take the manual gearbox out of and diff etc to convert my 98 rz-s tiptronic into 6 speed manual..
Now after lots of reading and searching this is what I have come up with..
Need off it list...
Gearbox/clutch flywheel (v160) etc
Rear b303b diff driveshaft's etc
Prop shaft
Need to find a centre tunnel prefer new (cant find part number to order...
Brake pedal clutch pedal and brake cylinder..
Gearbox speedo sensor wires
Traction controller sensor?
Now I am sure I have missed a couple of bits but I have 2 complete running cars (donor and the auto) to play with..
Now here are my questions which I cant seem to find on google etc
The 2 ecus in each car ie my auto vvti ones, and the 94 rz manuals ones, which ones will I use??
Will the big master cylinder be the same in both cars (its looks the same)
The other cylinder is only in the manual so I know I need that and to fit/drill firewall etc
I have read that thread//blog on the American full conversion but that's kind of not what I am doing here..
Hopefully some one can help and explain for me the ecu issue?? and the master cylinder too??
Cheers guys and girls :)
Definitely better with the manual ECU as David has suggested. There are different limiters in the auto's etc. I can't recall, but it may not rev past 4k when at a standstill for example.
You'll need the clutch master cylinder and slave cylinder also.
Guest SCOOBYKILLA
Ok cheers guys I will track down a vvti (guessing aristo or supra one will do) manual ecu.. maybe a daft question but the huge disc cylinder that's the same hey?? I just need the one to the right of it installed...
This will be my first conversion so all is new to me...
Guest SCOOBYKILLA
yeah will scour ebay for it found some already but they advertise it for the aristo and supra that's why need to get the part numbers...
Guest SCOOBYKILLA
cheers for the part number and for the clarification!! I shall get online later today and order the tunnel from some were.....
And thanks again :-)
Gonna start the dismantling of the rz on Thursday should be fun!!
Guest SCOOBYKILLA
Ok cheers for that wont bother, been reading up on my ecu, and it maybe worth keeping onto it for now as a few people reckon (on google) that my ecu will run the car fine...
