Notts_TT Posted February 12, 2016 Share Posted February 12, 2016 Hi everyone My supra has been sat and not run for probably 2 years. Today I went to jump it off my van and hooked up leads and started, it started straight away, when I pulled off leads it cutout. Jumped again and noticed volt gauge was jumping all over between 4 volts and 14 volts. So I put battery on charge and car started immediately and purred away beautifully. Checked output on battery and it was at 12.6 ish so guess Alts not charging, 120a fuse looks ok too. I also did a parasistic drain test and it came out at 0.35 on 10amp setting which I think is high, pulled AM2 fuse and it dropped to 0.18. What could this be ??? Something wired to ignition ??? Thanks Dan Quote Link to comment Share on other sites More sharing options...
Notts_TT Posted February 13, 2016 Author Share Posted February 13, 2016 Any help would be appreciated x Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted February 13, 2016 Share Posted February 13, 2016 The draw is too high, but if I had to guess I'd say the main issue is that the battery is knackered. Take it down to your local Halfrauds, and get them to do a battery health test on it. Iirc the battery voltage should be something like 14.5v if it's healthy. Once you've sorted that, remove any obviously added wires from the battery + terminal, and if there's an aftermarket alarm, try disconnecting that too. failing that, start pulling fuses from the engine bay and cabin fuse boxes, it should be obvious where the issue is coming from. In my experience, these issues are almost always caused by aftermarket goodies such as alarms, stereos/amps, HID headlights etc. Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted February 13, 2016 Share Posted February 13, 2016 You'll need to figure out what is on the am2 circuit, to establish which item is causing the draw, but it is definitely too high. It sounds like your alternator isn't charging correctly either. Check the 3 pin wiring plug first, and test for continuity on the wires. If they come back ok, then you may need to replace your alternator, or have it rebuilt Quote Link to comment Share on other sites More sharing options...
