dfrancis85 Posted February 12, 2016 Share Posted February 12, 2016 From a 1992 Aristo 2JZ GTE. Only done only 85KM, great working order. Looking for £200, collection from St Ives Cambridgeshire or buyer arrange collection due to weight. Link to comment Share on other sites More sharing options...
j_jza80 Posted February 12, 2016 Share Posted February 12, 2016 I don't think these are compatible with the Supra. - - - Updated - - - I don't think these are compatible with the Supra. Link to comment Share on other sites More sharing options...
David P Posted February 12, 2016 Share Posted February 12, 2016 That's a pretty one. Do you have the prop, or front section of prop to go with it? I never have, yet the prop-flange and/or tail sections I understand can be swapped to make it alternative auto prop compatible, the breather could stay and the sockets and plumbing are plug & play. Alternatively, this could be Hybridised without d!ck!ng with the tail section and used for a V8 Soarer installation and utilise the stock Soarer prop. J_Meiser is planning to fit a Hybrid to his 1UZ-FE and could be interested, the Aristo front prop section would mate with a T.T. Supra rear section to make up a pair that would fit his Supra. Delboy52 is a source for either the tail shaft components required to convert the box, or the rear T.T. auto prop section for plan B. I'll link this thread to the find it section in the Transmission Group. Link to comment Share on other sites More sharing options...
dfrancis85 Posted February 12, 2016 Author Share Posted February 12, 2016 I don't think these are compatible with the Supra. - - - Updated - - - I don't think these are compatible with the Supra. Thanks mate, I will update the title to reflect. Link to comment Share on other sites More sharing options...
dfrancis85 Posted February 12, 2016 Author Share Posted February 12, 2016 That's a pretty one. Do you have the prop, or front section of prop to go with it? I never have, yet the tail sections I understand can be swapped to make it T.T. auto prop compatible, the breather could stay and the sockets and plumbing are plug & play. Alternatively, this could be Hybridised without d!ck!ng with the tail section and used for a V8 Soarer installation and utilise the stock Soarer prop. J_Meiser is planning to fit a Hybrid to his 1UZ-FE and could be interested, the Aristo front prop section would mate with a T.T. Supra rear section to make up a pair that would fit his Supra. Delboy52 is a source for either the tail shaft components required to convert the box, or the rear T.T. auto prop section for plan B. I'll link this thread to the find it section in the Transmission Group. Thanks appreciated, I'm afraid this is all I have, no prop I just purchased the engine and box together. The engine is going in my kit car and the I have already converted it to a BMW manual. OEM ECU will be going up for sale next as I'm going single turbo. Link to comment Share on other sites More sharing options...
David P Posted February 12, 2016 Share Posted February 12, 2016 Supra's don't like Aristo ECU's. I have alerted JM, it shouldn't be too much hassle to find either a T.T. auto or Aristo front prop section? Or maybe he already has this on his present build? Folks either bin these things, or think they are rare items. Link to comment Share on other sites More sharing options...
J-Meiser Posted February 12, 2016 Share Posted February 12, 2016 Thank you for the alert David! As long as I can verify that either the flange is the same size as the one fitted to the Soarer's A341 'box or that I can get hold of an Aristo intermediate shaft if the flange is a different size, then I am interested! Link to comment Share on other sites More sharing options...
David P Posted February 12, 2016 Share Posted February 12, 2016 If you buy it, make sure that you get all of the no. 11 crank and torque-converter bolts, I have just given the last of my No. 11 crank bolts to Jagman for his 1J-GTE Flappy-Paddle Hybrid Soarer build. We can use the flex-plate, torque-converter, bell-housing, sump, dipstick and cross-member from your present transmission to suit it to your V8 application and with a bit of tweaking about, an N/A bottom fluid line becomes a plug & play fit. Link to comment Share on other sites More sharing options...
J-Meiser Posted February 12, 2016 Share Posted February 12, 2016 If you have it, make sure that you get the flex-plate and torque converter bolts, we can use the sump and dipstick from your present transmission to suit it to your application. Link to comment Share on other sites More sharing options...
dfrancis85 Posted February 12, 2016 Author Share Posted February 12, 2016 Haha how weird... Just realised that I know J-Meiser...! I used to play B ball with him! J, I'll call you tomorrow mate and we can work out if it will fit.. Or you can just take it for a while and mock up. Small world! Thanks for the hook up Dave P Link to comment Share on other sites More sharing options...
David P Posted February 12, 2016 Share Posted February 12, 2016 You're welcome, I hope that you enjoy hooking balls again like you did in the good old days. Link to comment Share on other sites More sharing options...
J-Meiser Posted February 12, 2016 Share Posted February 12, 2016 Haha how weird... Just realised that I know J-Meiser...! I used to play B ball with him! J, I'll call you tomorrow mate and we can work out if it will fit.. Or you can just take it for a while and mock up. Small world! Thanks for the hook up Dave P It's a small world indeed! No worries, speak to you tomorrow ! You're welcome, I hope that you enjoy hooking balls again like you did in the good old days. I'm sure that we will Link to comment Share on other sites More sharing options...
David P Posted February 13, 2016 Share Posted February 13, 2016 That snatched success from the jza of disaster. df, That previously believed impossible feat was so slick that I forgot to compliment you or whoever, for correctly preparing the torque converter for transport or storage, fortunately, we don't need the lines. Lovely and clean too for a nice change. Link to comment Share on other sites More sharing options...
