Elmo Posted February 11, 2016 Share Posted February 11, 2016 It seems that the flasher relay may be on it's way out. When unlocking the car with the alarm fob the indicators flash and on occasions the N/S indicators will stay on, if I play with the indicators all of the indicators will stay on (constant, not flashing), eventually after turning the alarm on/off, on/off etc. the indicators go back to normal, and the indicators will work fine while driving. I am trying to find the relay, I am aware that it is located somewhere in the drivers footwell, I have had a look but I can't see anything, is it hidden behind a panel or something? Also, can anyone give me the part number for the flasher relay? Cheers Link to comment Share on other sites More sharing options...
mellonman Posted February 12, 2016 Share Posted February 12, 2016 It should be behind the panel by the throttle on the side iirc Link to comment Share on other sites More sharing options...
and1c Posted February 12, 2016 Share Posted February 12, 2016 Here you go. Link to comment Share on other sites More sharing options...
Elmo Posted February 13, 2016 Author Share Posted February 13, 2016 Cheers guys Link to comment Share on other sites More sharing options...
