not boosting properly
ben_harmer32
Car was running fine would boost easily to 1.2bar.
At the weekend I fitted a metal air intake.
After car felt odd. Had a look an saw one of the vac pipes had got clamped between the intake and a metal engine pipe. (black one)
I got the pipe out and car felt better but since then it won't boost properly. It'll hit just over 1.0bar then drop to just over 0.5bar and won't go any higher. (possibly second turbo not kicking in?? But not sure)
I have checked the pipe that was trapped and can't see any damage. I also had the top intercooler pipe off whilst fitting but again can't see any damage and they are done up tight.
Any ideas please? :(
Edited by ben_harmer32 (see edit history)
  • 2 weeks later...
It sounds like you've affected the Exhaust Gas Control Valve, and it's not opening now. If it doesn't open, then the exhaust gas from turbo 2 can't flow out the exhaust, so #2 doesn't spin. Turbo #1 carries on doing all the work and you sit at 0.5bar with little power as it's overspeeding and overheating the air charge (don't carry on doing this btw, you risk detonation).
The overboosting to 1.4bar sounds like you've affected the wastegate system as well, and that's the second VSV in that area. You really need to pull the intake off again and check everything for damage etc :)
