ripped_fear Posted February 9, 2016 Share Posted February 9, 2016 So my car is going to be having some work done next month and we are on a tight time schedule so want everything bought before hand. My current OEM bumper hangs a little lower than it should as you can see in the picture below- It also has a fair amount of movement if you pull and push on it. I know the front bumper is fitted via the bolts on either side below the wing, the bolts along the upper edge, and the ones that go in the mouth up into the crash bar. Now looking at the EPC there is two support brackets in this picture, two either side under the head light, do you think this is what im currently missing, I havent removed the front end on my car yet to take a look? Think they can bee seen on this picture of my old supra. Just want to check before I add them to my next order tomorrow. Quote Link to comment Share on other sites More sharing options...
David P Posted February 9, 2016 Share Posted February 9, 2016 Look before you leap? Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted February 9, 2016 Author Share Posted February 9, 2016 Look before you leap? I dont want to take the front bumper off just to look at that, to then put it back on and them remove a few weeks later. if we think thats the cause I will just buy them for the sake of a few quid. Quote Link to comment Share on other sites More sharing options...
David P Posted February 9, 2016 Share Posted February 9, 2016 If leaping before you look floats your boat, grease up your wallet and grimace. Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted February 9, 2016 Share Posted February 9, 2016 If you take a headlight out you should be able to see the clips you are talking about, if not then they are missing Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted February 9, 2016 Author Share Posted February 9, 2016 Thanks guys but remembered the old build thread for the car is on here......and result there missing! Nice simple fix Quote Link to comment Share on other sites More sharing options...
Nic Posted February 9, 2016 Share Posted February 9, 2016 I dont want to take the front bumper off just to look at that, to then put it back on and them remove a few weeks later. if we think thats the cause I will just buy them for the sake of a few quid. Does the bumper have the stock polystyrene absorber/reinforcement fitted inside it? Removing the headlights is a fairly easy job and should help you see what's going on, it may actually be the headlight fitting rather than the bumper that is the cause of the gap. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted February 9, 2016 Author Share Posted February 9, 2016 (edited) Unsure nick, but I have the polystyrene absorber here ready to be fitted on the new OEM bumper, and I had the head lights out the other month and the sides seem to be bolted up correctly. But as above the 4 bits are missing so will get them on order too. Edited February 9, 2016 by ripped_fear (see edit history) Quote Link to comment Share on other sites More sharing options...
David P Posted February 9, 2016 Share Posted February 9, 2016 There are 4 x 10mm nuts to undo and do up again, with your record, to be sure you'd better get a dozen of those. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted February 9, 2016 Author Share Posted February 9, 2016 There are 4 x 10mm nuts to undo and do up again, with your record, to be sure you'd better get a dozen of those. never have an issue with body work stuff, always mechanical stuff. Not my realm. You cant give me abuse, you painted your bonnet yet Quote Link to comment Share on other sites More sharing options...
JackyBoi Posted February 9, 2016 Share Posted February 9, 2016 When I removed my Top Secret front there was nothing but around 8 x 10mm nuts/bolts holding it on and it did an excellent job from Japan right up until I took it off. If I were you (which I'm not lol) I'd just use nuts and bolts! Quote Link to comment Share on other sites More sharing options...
David P Posted February 9, 2016 Share Posted February 9, 2016 That'll get done after I have bonded on and blended in the JDL bonnet extension, my front bumper is nailed on properly though. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted February 9, 2016 Author Share Posted February 9, 2016 When I removed my Top Secret front there was nothing but around 8 x 10mm nuts/bolts holding it on and it did an excellent job from Japan right up until I took it off. If I were you (which I'm not lol) I'd just use nuts and bolts! May have worked for the after market front but you have limited fixings on the OEM one anyway, for the sake of a few quid i will be ordering them. May as well do it properly once. Thanks though, just want to be safe. That'll get done after I have bonded on and blended in the JDL bonnet extension, my front bumper is nailed on properly though. Nails now there is an idea. Off to B&Q Quote Link to comment Share on other sites More sharing options...
