johnd-mkiv Posted February 9, 2016 Share Posted February 9, 2016 Starting to get what looks like turbo seal failure, done a compression check all looks good, I have the above turbo where would be best taking it? The shaft has play seems a lot to me Do DBB turbos have more than usual? Link to comment Share on other sites More sharing options...
Supraleeturbo Posted February 9, 2016 Share Posted February 9, 2016 Owen developments are really good bud Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 9, 2016 Share Posted February 9, 2016 Ball bearing turbos usually have less radial and axial play on the shafts than journal bearing turbos. Link to comment Share on other sites More sharing options...
Jellybean Posted February 9, 2016 Share Posted February 9, 2016 Owen developments is where all the cool kids are going these days , you dont seem to hear much about Turbo Technics or CR turbo's any more Link to comment Share on other sites More sharing options...
TBDevelopments Posted February 9, 2016 Share Posted February 9, 2016 I can probably get you a replacement chra for that turbo Tim TBDevelopments Link to comment Share on other sites More sharing options...
johnd-mkiv Posted February 10, 2016 Author Share Posted February 10, 2016 I can probably get you a replacement chra for that turbo Tim TBDevelopments Did you mean core? I've spoke to a few being as its not a well known turbo they need to look at it to make sure they can get he parts, if you can supply one I'm interested Regards John Link to comment Share on other sites More sharing options...
TBDevelopments Posted February 11, 2016 Share Posted February 11, 2016 basically yes. CHRA = Centre Housing Rotating Assembly Tim TB Developments Link to comment Share on other sites More sharing options...
