Is this centre console lid repairable?
tintinmt
Easy peasy fix. There are 2 metal rods, they loosen up and come out of the holes, if you have a small enough pliers you can pick at them and push them back in, unless that L shape plastic bit is busted. It might have fallen in the hole...if you can find it, araldite it back on.
Thanks guys! The L shaped bit is busted so needs something to retain the metal rods. Its tempting to think there is a fix but probably involves removing the console and it may then easier to just replace the whole thing. And yes - it does need a bit of a clean afterwards!
  • 2 weeks later...
