condensation in headlight
Big Stu
Just a thought, what bulbs are fitted? They should be HB3 and HB4, sometimes when UK glass headlights are retro fitted the bulbs from the j-pec headlights (usually both HB3) are used, if this is done the low beam bulbs may not be sealing properly. Also check the drain tube on the back of the lights is not blocked/kinked and is pointing downwards. I'd remove the headlights first and dry them out thoroughly before refitting.
