European Diff Cooler
Stu Hagen
I have recently purchased a used Euro Diff cooler and related parts. I have tons of reference manuals but I have nothing on this. I would like to source the FSM for the installation, servicing and electrical connections. If anyone can give me a link to these I would greatly appreciate this. TIS blocks me out in UK/Euro spec Supra's. My website where I host lots of this stuff lacks Euro info. http://www.97supraturbo.com
TIA
Stu
To share what I told Stu, the diff cooler ECU and relay are behind the right rear quarter panel, next to the seat belt spring.
Other than the ECU and relay there's a 30A fuse, the pump and temp sensor (obviously), and wiring to ignition as well as to the check connector under the bonnet (pin 20, OP2)
Hello Stu how are you .
At EU Spec Cars the Differential Ecu is behind the right rear Speaker panel.
The Cooling is nothing Special Oil pump on top of Diff and Oiltemp sensor at the bottom of Diffcover .
At your US Spec Diff you find the the Points for Mounting the Pump but you have to drill some Holes for Pumpbracket and Oilstrainer Hosefitting .
Grettings Marc Knoll
